Old 03-04-2012, 08:55 PM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
Originally Posted by GearHd6 View Post
Looks to me like the U-bolts that go around the front axle and attach that bracket are loose. The install looks correct, just tighten the U-bolts.
I think you've got a kit similar to this: http://www.suspensionconnection.com/...con/66391.html
That large bracket looks exactly like the one that is loose. I'll try to tighten it up, but the design looks like it is very susceptible to movement. Not sure that is such a great design.
I'm think I'm going to drill a hole in the bracket and run a bolt through the control arm, like CdnoilRam hinted at.
Old 03-04-2012, 09:16 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
If those clamps are tight you'll have a hard time getting any movement out of that setup. Just remember that the axle and the trackbar move at different rates. You'll be putting added stress on the bracket attaching it to the trackbar.
Old 03-05-2012, 01:13 PM
Color: Flat Black
That's a good point. I might hold off on attaching it to the trackbar. My 35" tires should be here in a day or two. I think I'll see if I can tighten the brackets down for now, get an alignment when the tires arrive, and do some test drives.
Old 03-11-2012, 01:42 AM
Color: Flat Black
So I tightened up the center bracket, and it came loose again. When I tightened it up the second time, I broke on of the U-bolts. So after tightening the one that was left, I had someone weld the other side to the axle.
Here's where someone can learn from my mistake:
I didn't have the bracket centered, and now I have really screwed up my turning radius.
I'm going to hope I can find something like a piece of unistrut, cut it down to 6-8 inches, and I see if I can put it in the center between where the two shocks meet, thus (I think) increasing my steering radius.
Old 03-12-2012, 10:22 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
I was gonna say I have that same set up and it looks right just probably needed tightened.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 03-17-2012, 08:06 PM
Color: Flat Black
I blame myself for not translating the directions with the tork settings. I translated all the instructions for the lift kit, but not the steering stabilizer. I found some other issues, while going through this, however, and it was a good learning experience.
