Towing Milage Boosted Hemi's - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 03-03-2012, 10:25 PM
azzo540 azzo540 is offline
Vehicle: 07 Hemi Ram QCSB 4x4
Trim Level: laramie
Rep:21
azzo540 is on a distinguished road
Send a message via Yahoo to azzo540
Default Towing Milage Boosted Hemi's
ok i am about to tow 4000 miles from wa to ga the long way through la, vegas, st louis.
back to the point.
i got a 07 ram QC 4x4 supercharged hemi with ats diesel tranny and other modds not woth note here.
she can run 8.4 psi, normal driving i see 2 psi accelerating.
i was wondering what boosted trucks see on tow milage
non boosted post for comparision.
need and idea for money need to save
Haulin 20ft car haule with house hold goods aswell about 6k in trailer.
thanks
07 1500 QCSB Laramie "Black Betty" Magnuson supercharged, "ATS Diesel" Tranny w/ TCI breakaway TC, Dynatech Super Maxx LT headers, FM Cat-back, K&N
custom doors courtesy of "Axle Break Hill"
Old 03-03-2012, 10:37 PM
Rep:3347
If you're boosted you should actually see better mileage than the n/a guys because you can see more charge air at lower RPMs once you get the 'charger spooled up. For reference, modified n/a motor, when towing I see 13-15mpg and non-towing is 17-20 running a custom 91 tune.
Old 03-03-2012, 10:45 PM
Trim Level: laramie
Rep:21
i see 1 psi at 1700. you 13 mpg at 2500rpm?
Old 03-04-2012, 12:22 AM
Rep:3347
With tow-haul on, towing on level ground at 120km/hr I'm usually in the 2000-2400 RPM range, but through the mountains I'm typically in the 2800-3500RPM range where my current 6.1L cam makes the best torque. In our gen, the T/H function disables the MDS, so there goes a lot of possible fuel savings, plus I typically downshift manually going downhill and let the trans do most of the braking then use my truck and trailer brakes to control speed.
