OEM brake caliper any good? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 03-04-2012, 02:07 PM
trx4dogger trx4dogger is offline
Vehicle: 2008 Dodge ram
Trim Level: TRX4
trx4dogger is on a distinguished road
Default OEM brake caliper any good?
Have a 2008 TRX4 1500 with 15,000 miles. pretty much only use it for weekend fishing and hunting in a 75 mile radius. Yesterday out of the blue front passanger brake stuck. Happened to be close to my work which has some open area in the warehouse. Pulled in there and pulled the wheel. A caliper piston was stuck holding on the brake. Rotor scored, everything smoking hot. I pulled out the brake pads thinking I could drive it to the shop and leave it for them on Monday.Mistake, it let the piston come out too far i guess and blew all the brake fluid. Funny I am having this problem because I am one of those guys that are easy on brakes. No riding the brakes, no accelerating to within a short distance and slamming on the brakes. Pads had almost no wear. So I told you all that to ask this. I don't need this happening in the remote areas I go to. Should I just have the OEM caliper rebuilt and call it a fluke? Or bite the bullet and upgrade to some aftermarket system on both fronts to gain reliability?
Old 03-05-2012, 02:46 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i think it is a fluke, but i would hate to see you get stuck in the middle of no where on my say so. 3 dodges and only replaced pads, never a caliper. you seem to drive so few miles i am wondering if the truck sits too much causing the problem.
Old 03-05-2012, 08:35 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
All my families dodges which have been too many to count on two hands have never had anything but normal pad/rotor wear. sound like you got that one that just doesnt wanna work right
2011 Big Horn 4x4 -SnowWhite-
Old 03-06-2012, 11:40 PM
345cube 345cube is offline
Vehicle: 2008 Ram 1500 Hemi QC 4wd
345cube is on a distinguished road
Had this happen to me before. 08 Ram 1500, passenger caliper stuck at 40k miles.
2008 Ram 1500 QC 4wd
Bilstein 5100's - all 4 corners/eBay drilled-slotted ceramic brakes
Old 03-07-2012, 07:40 PM
TurboCup87 TurboCup87 is offline
Vehicle: 2012 1500 Sport Crew 4x4
Color: Blue
Rep:28
TurboCup87 is on a distinguished road
occasionally any caliper can get a stuck piston. I had one once in a 97 Expedition with 100K miles. Just need to get it fixed and use it.
Old 07-06-2012, 06:45 PM
07TORAMU's Avatar
07TORAMU 07TORAMU is offline
Vehicle: 2007 DODGE RAM 1500
Trim Level: BIG HORN
Color: blue
Rep:13
07TORAMU is on a distinguished road
mopar replacement parts i feel always better due to there construction of being built,being a mechanic a dot 3 system (fluid) get over 300 degress when brakes apply.i think u just got a bad part,if u drive truck at least 2 times out of the month lets say,then u would be ok.there actuall componets in a caliper like a porpotioning valve,also at all times there is a certain amounf of fluid in the caliper for front and rear,it recommend to do a complete brake flush every 30 thousand miles to remove all the old brake fluid,due to deposits can screw up the caliper....hope this helps
