Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Diablo Predator Questions & Info!
Old 03-05-2012, 02:48 AM
crackerzach86 crackerzach86 is offline
Trim Level: SLT Big Horn
crackerzach86 is on a distinguished road
Default Predator setup
Ive had the predator for about a year now and I'm always making adjustments to try and make it faster, I'm curious as to how far anybody has advanced there timing without getting the infamous knock. Right now I've got it advanced 4deg at wot and I'm running 4% added fuel at wot, this made a huge difference in power. I'm running the 91 octane tune. Any help is appreciated, also if you have a setup that works well for you and you're willing to share I'd appreciate it.
Old 03-05-2012, 11:27 AM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Record your LT and ST knock retard, that will tell you if your getting knock.
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 03-05-2012, 12:29 PM
This may sound dumb but what do you mean by lt and st? And also how will these numbers tell me if I'm getting knock or not?
Old 03-05-2012, 06:12 PM
FDBDW's Avatar
Rep:172
Not dumb at all thats why we are here , to learn and to pass on info.
When you have knocking your computor senses it and retartds the timing in that range. St is short term knock and it resets when the truck is shut off, a little STK here and there is normal usually about 1-3 degrees if it gets over 5 or is consistent throughout the power rangethen adjustments need to be made. When there is consistent knock in a certain range the computer will remember it as LTK long term knock retard. Hope this helps, do some logging and see what you get, pull some hills do some WOT. If you want, post your numbers and we'll se if we can help.
