Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 03-05-2012, 11:03 AM
ejjr5046 ejjr5046 is offline
Vehicle: 2012 ram st 1500 crew
Trim Level: st
Color: metallic grey
ejjr5046 is on a distinguished road
Default is second glove box simple conversion
Hello,
I picked up my 2012 ram 1500 crew and desire additional storage. over my "standard" glovebox, is just a deep cubby hole.
Does anyone know if I can purchase the "door and insert that is on the higher end models and have it work?
thanks
eddie
Old 03-05-2012, 11:32 AM
moparornocar72's Avatar
Rep:630
I think its all one piece and shouldnt be hard to change out
14.268 @ 95 MPH Full Trim
Old 03-05-2012, 11:56 PM
NMBowtie's Avatar
NMBowtie NMBowtie is offline
Vehicle: 2000 Dodge Ram 2500
Color: Blue
NMBowtie is on a distinguished road
I swapped mine. You need the door, the bin that goes with the door, the metal striker for the latch, and some screws. I found all the parts to do mine at a local wrecking yard and ended up paying about $30 for the pieces (but I bought a bunch of other stuff too).
There is one screw holding the cubby in place (drop the lower glove box and you will see it toward the back) and the rest is spring clips around the front that pop out. The door then slips up into place. It is kind of tough to wiggle it back in where it goes since the hinges are somewhat "goosenecked" and slip up behind the top of the dash. The screw holes are there for the hinge, so it attaches easy. The cubby that goes with the covered glove box then pops in with the spring clips and the same screw that held the original cubby. The latch striker then attaches at the bottom with two screws into existing holes.
Pretty easy swap overall, took probably 15 minutes. The only thing I haven't done with mine is wire up the light in the upper glove box. I didn't see a harness tucked in the dash anywhere, so I will probably splice into the wiring for the 12v power receptacle.
Old 03-06-2012, 10:27 AM
Trim Level: st
NMBowtie
thanks!!!! I knew someone had to have done it
