Old 03-05-2012, 05:23 PM
S77R's Avatar
S77R S77R is offline
Vehicle: 2010 Dodge Ram 4X4
Trim Level: Crew Cab SLT BigHorn
Color: Inferno Red
S77R is on a distinguished road
Default Console Power Outlet Not Working
Hello, the 12vDC Power Outlet in the center console next to the shifter is not working. I tried plugging in a few different items but nothing worked. But the power outler in the armrest compartment and the outlet in the back of the console for the rear seats still work. Are these power outlets all on their own fuses? If so, which one is for the power outlet next to the shifter? thanks for the help.
2010 RAM CrewCab BigHorn 5.7L Hemi - 3.92/LS
18" Boesch Muffler kit - Moroso Catch Can
Old 03-05-2012, 06:25 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
My console outlet only works when the key is on. I think the other ones work all the time.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
Old 03-05-2012, 06:32 PM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
Jay
This, but also, that outlet was the only one on my truck that wouldn't work unless I pushed the cigarette lighter plug-in to the side. I fixed it by removing it from the truck and bending the contacts inside to have more tension. Might check the connections inside if it does not work when the truck is turned on.
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
Old 03-06-2012, 08:04 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
You've probably got a blown fuse.
according my owner's manual, it appears that each of the three power outlets are on separate fuses.
Everything is controlled by the Totally Integrated Power Module (TIPM), located in the engine compartment, near the battery
MF31 20amp Power Outlet #1 (battery)
MF48 20amp Power Outlet #2 (ign r/acc)
MF49 20amp Power Outlet #3 (ign r/acc / battery)
I would check MF49 to see if the fuse is blown. I'm reading the ignition/ ACC or Battery tag to mean that you can change the position of the use, causing the power outlet to either be on with the key, or to be hot all the time. This was an option in my wife's Magnum, so it may be an option in our trucks too, though I haven't gone out to look yet.
good luck, and let us know what you find
Exco
Bill
Old 03-09-2012, 10:24 PM
S77R's Avatar
Color: Inferno Red
FYI for those following the tread. I checked all 3 fuses and the MF48 20amp Power Outlet #2 fuse was the culprit. Its was burnt up. I am gonna head to the store this weekend to get a new one. thanks for all your guys help!
Old 03-12-2012, 09:05 AM
Excoastie's Avatar
Rep:1358
glad that you got it figured out. I would try and figure out what caused it to blow...
did you plug something in to it that over loaded it? did you plug something in that had some sort of short in it? was it that way when you got the truck so you have no clue? do you currently have a short?
If you replace the fuse, and it immediately blows again, I'd get it checked out, as that indicates that you've got a short somewhere, and that the fuse did what it was designed to do
good luck
Exco
Bill
Old 03-12-2012, 11:09 AM
cwsomerton cwsomerton is offline
Trim Level: TRX4 Off Road
Color: Black/Grey
cwsomerton is on a distinguished road
This also happened to me, no power on the center console outlet. The dealer ended up replacing the socket and some wiring under warranty, turns out the wire was pinched in the console and ended up being chaffed off.
Old 04-12-2013, 02:01 PM
Markdb Markdb is offline
Vehicle: 2012
Color: Grey
Markdb is on a distinguished road
Mine just stopped working and I checked and the fuses were good. Now what?
Old 04-24-2013, 02:30 PM
JimmyNichols's Avatar
JimmyNichols JimmyNichols is offline
Vehicle: 2011 Ram 1500
Color: Mineral Gray
JimmyNichols is on a distinguished road
Giving this a bump. I am in the same boat err truck. This happened to me while I was traveling. All 3 went out on me and the fuses all check good.
Old 08-01-2013, 10:17 AM
Pov7Hemi's Avatar
Pov7Hemi Pov7Hemi is offline
Vehicle: 2013 1500 4x4 Crew Cab Hemi
Color: Bright Metalic Silver
Rep:28
Pov7Hemi is on a distinguished road
Just searched out this thread.And,man was it helpful in my new 2013.Only one fuse which could be switch over and it was for the rear seat 12 volt outlet.Constant 12 volt power!
Thank you Excoastie!!!
