Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 03-05-2012, 07:04 PM
ohcnda ohcnda is offline
Vehicle: 2012 Dodge Ram Sport
Trim Level: sport. loaded.
ohcnda is on a distinguished road
Default Oil change intervals
i was looking at the manual today to see the type of oil i needed to pt in the truck when i noticed it says to change every 13,000 kms? this is more than double the usual 5000kms i would have done in my Ford. is the oil a synthetic? any input would be great as i am going on a road trip and i wanted to have fresh oil in it before i leave!
Old 03-05-2012, 07:48 PM
MoparDude's Avatar
MoparDude MoparDude is offline
Vehicle: 2012 1500 Hemi Crew
Color: Deep Cherry Red Crystal Pearlcoat
MoparDude is on a distinguished road
I am thinking the same thing... that's a long time between changes. I am going to swap to synthetic, just have to make sure it has the MS-6395 rating (Mobil 1 for extended mileage vehicles). That and a Wix filter after 5000 kms. I ran Castrol Syntec in my 97 Dakota without the rating with no issues...
'12 RAM, '08 R/T Avenger, '66 500 ci. Belvedere
You save the environment, I'll save my dignity.
Old 03-05-2012, 08:06 PM
Snuffy's Avatar
Snuffy Snuffy is offline
Trim Level: Lone Star
Snuffy is on a distinguished road
Oil is the cheapest thing you can put in your engine, I have thought of going to the sycthetic oil, actually did so on a 2011 Jeep I traded in.
I am not a Penzoil man myself but with the deal buy one get the next 3 free I am now. I will be chaning my oil every 3,000 miles or so. The cleaned you keep the engine the longer they last change oil often and a new filter every time, works for me.
Cowboy Woe's first I shot over then I shot under then I missed!!!
Old 03-05-2012, 08:08 PM
jacobson.s's Avatar
jacobson.s jacobson.s is offline
Vehicle: 2012 Dodge Ram 1500
Color: Deep Cherry Red w/Silver Trim
Rep:61
jacobson.s will become famous soon enough
Yup its 13,000kms, I will be using 100% synthetic oil by Amsoil. And a quality filter.
Mods: Chrome bug deflector, chrome tailgate handle, chrome splash guards, chrome mopar fuel door,WeatherTech floor mats, bug screen behind grille, cabin air filter, painted calipers red...
Wish List: 2013 Ram Headlights, LED Taillights, Tonneau Cover, HIDs, CAI, Exhaust System, Power Locking Tailgate, Catch Can...
Stupid Expensive MODS
Old 03-05-2012, 08:21 PM
zabman's Avatar
zabman zabman is offline
Vehicle: 2009 Ram Sport
zabman is on a distinguished road
Your wasting good oil changing it every 3,000 miles.It will last at least twice that long.
Old 03-05-2012, 08:33 PM
MoparDude's Avatar
Likely true... especially when it hold 7 litres. When I replaced my timing chain on the Dakota at 160,000 kms the engine was spotless. That was a 3.9l V-6 changed at 5000 kms faithfully.
But 13,000 kms! I think I'll split the difference...
Old 03-05-2012, 09:09 PM
I push the skinny pedal
Rep:3277
Yeah, the 5,000km is the 'dealer recommended' interval... because they can charge you for it, plus try to find other things that 'should be looked at' while it's there. I dno't want to call them stealerships, because not all are that way and the 3000mile oil change is a hold-over from the '70s era when you had fuel blow-by in your oil and if you didn't swap it out then you'd kill your engine in a hurry. A quality synthetic can easily last you for 15-20,000kms and still be in good shape. If you went as far as doing regular oil analysis, then you could push that even further knowing you're still protected. Dealerships may argue the oil analysis results, so it's best to stick with the manual recommended intervals.
Kurtis
Old 03-06-2012, 07:33 AM
i am confused, i am assuming that the oil they are going to put in at the dealer is just conventional oil, not synthetic? most of you guys are talking about using synthetic... which should last areound the 13000 km mark. i was most concerned about using the mopar oil for that long of time.
Old 03-06-2012, 07:36 AM
how could they argue with the analysis? the proof is there?
Old 03-06-2012, 08:11 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Your truck should be equipped with a "duty based" gizmo that will tell you when it needs to be changed. You'll get a message in the EVIC that says something to the effect of "oil change needed".
I myself am not real sure that this message is in fact duty based, as mine like clock work goes off EVERY 2500 miles, as did the one in the '08 I had (current truck is a '10 CC 1500 with HEMI). I change my oil myself every 5000 miles (usually use Mobil 1 oil and filter)
good luck
Exco
Bill
