Dodge Ram Decals
Old 03-05-2012, 09:56 PM
konarider2005's Avatar
konarider2005 konarider2005 is offline
Vehicle: 2009 dodge ram 1500
Color: inferno red
Rep:22
konarider2005 is on a distinguished road
Talking DIY LED floor lighting
iv been looking at doing the lighting since i bought my 09 ram sport and looked at several posts and threads that dealt with the mod, but since i was doing it i decided to bring my camera along and post up some pictures to help people in the future that are doing the same mod. i went down to a local hardware and wiring store and go 4-9" red LED strips ($10 a piece) that had mounting hardware with the kit the rest of the wiring and all that i had laying around the garage so it made for an inexpensive mod244.jpg. i popped of several covers and interior bezels so i could run the wiring without having it noticable, had a hard time finding a ignition power source and didnt want to strip,solder, and shrink wrap in factory wiring harnesses. i used a temperary power source which was a old 12 volt male plug and wire and ran ir from the back of my console to the switch and fuseable link (10 amp fuse) under the dash on a mounting plate i also found at the hardware store until i pull my center console apart to add rearview camera,subs and paint and airbrush the grey interior parts to match the truck, at the same time i will hard wire the lights to the 12 volt plug in next to my shifter.254.jpg 262.jpg 264.jpg 265.jpgi mounted the driver side front LED to a stiff 12 gauge wire i had laying around that went from one side to the other and zip tied it all along where i could until i find a more permanent mounting spot because there isnt mayn places to mount to under the stearing wheel and then ran all my wires under the dash and colsole to the pasanger side to the light i had mounted to the metal plate where the glove box sits. from there i ran my wire under the carpet to the back of the rear seats. i mounted the lights in the rear to the storage covers (temporary until i put the sub box in then i will mount next to each 10 inch sub facing the front). the red LED match my new Alpine nav unit perfect which my computer isnt allowing me to attatch a pic of... ill try later
if you have and questions about the install or comments please feel free and post below I will try and get back to all questions
2009 Dodge Ram 1500 sport 5.7L HEMI inferno red
2008 CAN AM outlander 800 xt
Old 03-06-2012, 12:01 AM
ABCRUDE's Avatar
ABCRUDE ABCRUDE is offline
Vehicle: 2011 Ram
Trim Level: SPORT
Color: BLACK
Rep:21
ABCRUDE is on a distinguished road
Nice touch. Not too bright. Great job
thanx for the how to and pics
LIFE HAS A TON OF CURVE BALLS
YOU JUST HAVE TO LEARN
HOW TO HIT THEM
Old 03-06-2012, 08:35 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
nice job! looks good
Exco
Bill
Old 03-07-2012, 01:15 AM
Color: inferno red
Rep:22
thanks for the reps exco! i drove for about half a hour with them on and the rear ones caught the corner of my eye which drove me crazy... sigh... back to the drawing board, gonna see how it looks mounted to the front seat back crossmember for the seat frame facing back. i did that on my 04 ram and worked great.
Old 03-07-2012, 08:15 AM
Excoastie's Avatar
Color: Hydro Blue
Rep:1358
you're welcome for the rep. It's one of the things we try to do when a member does a mod that looks good, or is a good inspiration, or has a pretty good write up
Some thing you might want to try, though I'm not sure how well it will work for you is to scuff up the lights a little bit. This will reduce the brightness and/or glare that you're seeing. I had to do this when I installed a red LED under the dash of my PT Cruiser.
I wanted to have a light shining down on my cup holders, but once the install was complete it was like I had a red spot light, instead of a little subtle glow. I hit it with some fine sand paper lightly. It was enough to cloud up and diffuse the light output, therefore reducing the spot light effect. In hind sight I probably should've done it wet, but it still came pretty well. I'm not sure how well it'll work with what you did though.
perhaps someone else will chime in
good luck
Exco
Bill
Old 03-08-2012, 10:03 PM
Color: inferno red
Rep:22
unfortunately with these ones i cant sand them down they have a rubber compound casing, but i relocated them to under the front seat facing to the rear of the truck and it looks awesome! very happy with how it turned out
Old 03-13-2012, 08:22 PM
Color: inferno red
Rep:22
picture of matching head unit is on different thread http://www.ramforumz.com/showthread.php?t=107412
enjoy any comment, concerns or questions feel free to comment
