Old 03-06-2012, 02:10 AM
zbaker08 zbaker08 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Gunmetal Gray
zbaker08 is on a distinguished road
Default 4.7L Magnum engine BBK Throttle body
Does anyone know if the BBK throttle body thats listed as being for the 1999-2003 4.7L engine will fit on the 4.7L in the 2004 rams? My understanding was that the '02-'07 4.7L engines were all the same, but there was no 4.7L engine in dodges prior to 2002 but somehow BBK advertises the TB for the 4.7L from 1999-2003. I only ask because i want to put a TB on my 4.7L but i don't want to order one only to have it show up and not fit. Anybody have any thoughts on this?
Old 03-06-2012, 09:01 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I don't think the 4.7L debuted until 2002. I'm not 100% positive though. I'd maybe contact airram and ask the guy there, he seems to know everything about the 4.7L's.
Sean
Old 03-15-2012, 02:41 PM
7186dodge's Avatar
7186dodge 7186dodge is offline
Vehicle: 2012 RAM 1500 SPORT
Trim Level: SPORT
Color: BLACK
7186dodge is on a distinguished road
jeeps had 4.7s first
Old 03-15-2012, 06:18 PM
AIR RAM's Avatar
AIR RAM AIR RAM is offline
Vehicle: 2002 4.7L QC RAM (9.49's 8th)
Color: SILVER
Rep:13
AIR RAM is on a distinguished road
The 1999-2002 4.7L engines had the JTec PCMs... which used a small Idle Air Control (IAC) mounted to the throttle body. The 2003-2007 4.7L throttle bodies came with the NGC PCMs and a Larger IAC mounted to the throttle body.
So you need to know which PCM you have...
If you have a J-Tec then the 70MM BBK throttle body will work with your application.
If you have an NGC throttle body then it will not.
SPEED SAFE, NICK
Old 03-15-2012, 07:57 PM
snrusnak's Avatar
Rep:1385
Glad to see you on here Nick!
Sean
Old 03-16-2012, 06:21 AM
Ballistix234's Avatar
Ballistix234 Ballistix234 is offline
Vehicle: 2005 Dodge Ram 1500 4.7L
Trim Level: ST Base-Base
Color: Pewter (Biege Met.)
Ballistix234 is on a distinguished road
I am looking to do the same modification, with a cold air intake. Is there a way tell the difference between NGC and Jtec Pcms? With out tearing the truck apart.
Old 03-16-2012, 09:04 AM
snrusnak's Avatar
Rep:1385
It sounds like you could identify which one you have by looking at the IAC on the TB.
Sean
2004 ram, 4.7l engine, throttle body
