Old 03-06-2012, 03:20 AM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
Default dropped the 09 QC 2wd PICS!
So i have had the Belltech 2/4 kit with SP shocks sitting in the garage for about two weeks now and i have had enough i just couldnt wait any longer. So i did the install this past saturday.
I started the with the front first just because it would give the most problems. not so. it was very straight forward, I even rented a coil spring compressor and
ended up not needing it, the springs came out pretty easy. then i turned truck around
(this is with just the front done, old school.....)
and the rear was even easier, until i tried to remove the stock shocks. I removed the wheel well liners from both sides and found out just like everyone had said, it was nearly impossible to get to the upper nut on the back of the upper mounting hardware with the standard tools i had. sockets would not fit and the standard size boxed wrenches were too long. So i had to break down and make a trip to autozone, I was looking for a stubby 21mm wrench but of course they did'nt have any. I ended up buying a set of crows foot wrenches,
and it ended up being perfect. 30 seconds and the shocks where off.
with everything double checked for correct torque i hit the road.
Ride was really close to stock. not harsh but a bit tighter, less body roll. handles very well on winding back country roads. I did bottom out the rear once. on a dip at the bottom of a low spot on the road near my house, but it was pretty bad even when it was stock. I am very pleased with the results.
and from day one to current
I also took measurements before and after just so you can see the difference.
Driver FT stock=36"-Driver FT lowered=34.5"
Passenger FT stock=36"-Passenger FT Lowered=34.25"
Driver RR stock=38.25"-Driver RR Lowered=34 7/8"
Passenger RR stock=38.25-Passenger RR Lowered=35.25"
At rear bumper stock=23"-at rear bumper lowered=19.5"
Old 03-06-2012, 03:44 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Looks great! I want to drop my truck some day too.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 03-06-2012, 06:58 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
looks awesome man! I love the whole look of your truck
your neighborhood looks pretty freaking nice too
2011 Big Horn 4x4 -SnowWhite-
Old 03-07-2012, 12:48 AM
Ramfd's Avatar
Rep:150
Thanks guys I am pretty happy with it. Next up is getting rid of the rest of the chrome and painting the wheels.
Old 03-07-2012, 11:48 AM
UceJuice808's Avatar
UceJuice808 UceJuice808 is offline
Vehicle: 2009 dodge ram hemi
Color: brilliant black
UceJuice808 is on a distinguished road
I have a question. Did you notice your front tires sticking out pass your wheel fender? I put a McGaugh 2 inch drop spindle in the front and notice that my front tires aresticking out of my fender about a 1/4-1/2 of an inch. I want to know if it was the spindle that pushed it out. it if it was originally set like that by the manufacture. Any response would be appreciate thanks!
Old 03-19-2012, 04:05 AM
Ramfd's Avatar
Rep:150
no, the tires do not stick out on the front. I would say it is the spindles. Now the rear is different. My asle shifted to the passenger side by at least 1.2 in if not more. It is very noticable. It would be nice if some one had a track bar relocation bracket to relocate the axle in the center of the truck. also noticed the rear sway bar sticks down way below the asle too. I have read of someone cutting the links and welding the back together a bit shorter to ge tthe sway bar back to the stock location.
Old 03-19-2012, 08:05 AM
streetdrag streetdrag is offline
Location: Vancouver,Wa, Always On The Road Though Working
Vehicle: 2009 Dodge Ram 1500 SLT
Color: Stone White
streetdrag is on a distinguished road
Turned out good , they change in look so much with just a drop..
Old 03-19-2012, 02:01 PM
03lowram 03lowram is offline
Vehicle: 2011
Trim Level: Badass
Rep:19
03lowram is on a distinguished road
Looks good. I put a 3/5 drop on my ram this weekend and we couldnt get that damn 21mm nut off in the rear. Went to autozone to buy some crows foot wrenches and of course they were out. So this weekend ill put the SP shocks on in the rear. Were you able to get the liner back in there easy? I heard it was a pain in the ass!
Old 03-20-2012, 04:06 AM
teenRam's Avatar
teenRam teenRam is offline
Vehicle: 2014 Dodge Ram 1500
Color: The Best Color - Black
Rep:14
teenRam is on a distinguished road
Looks good
Old 03-20-2012, 04:30 AM
InDeepWaterBlue's Avatar
Rep:611
@UceJuice808 "I have a question. Did you notice your front tires sticking out pass your wheel fender? I put a McGaugh 2 inch drop spindle in the front and notice that my front tires aresticking out of my fender about a 1/4-1/2 of an inch. I want to know if it was the spindle that pushed it out. it if it was originally set like that by the manufacture. Any response would be appreciate thanks!"
It's the spindles that make the front tires stick out, a few others on the Z have had that same issue.
Wish I would have though of a crows wrench, I angled a regular box wrench to grip onto the bolt straight on and the used a pair of vise grips to hang onto the wrench
