Old 03-06-2012, 09:41 AM
Ramathorne Ramathorne is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl
Rep:48
Ramathorne is on a distinguished road
Default 180* Stat Info For Swap Today
Just wondering how much coolant I will loose & what to set my fan temps too after the install...I took the clutch fan off already...
Old 03-06-2012, 09:58 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I just did this on my 4.7L. It may not be identical to yours, but should be similar. I lost roughly 2 gallons total. I currently have my fan set to 197, may change that, but only time will tell...
Sean
Old 03-06-2012, 11:20 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
hemi or 4.7? the hemi won't lose that much because the tstat sits higher than a 4.7... I swap between my 170 and 180 on race days and lose less than a gallon (when I pull hose i face it upwards to minimize loss)
Old 03-07-2012, 02:07 PM
Rep:48
Well. The job is done. Anything to know or watch for while driving the first bit afterwards? I lost quite a bit of coolant. I added 1.75 liters of coolant amd 1.75 liters of water.
Old 03-07-2012, 02:24 PM
snrusnak's Avatar
Rep:1385
I had air trapped in my cooling system right after, the temp kept "spiking" fairly high (higher than with stock tstat). After a few cycles of letting it heat up and cool down I was able to top off the coolant and kept doing this for a couple days. Now it's perfect, the temp hangs around 190-195
Sean
Old 03-07-2012, 03:00 PM
Rep:48
Yeah I must of too...I went for a couple 10km drives...Temp was up into the 230F range...So I stopped, added some more a few times...Ended up using 3.75L of antifreeze and 2.25L of water....Now I am running 185-190F...Overflow tank is a bit high tho.....So I lost a bit more than I suspected...Actually quite a bit more...Not the best at estimating lol
Old 03-07-2012, 03:17 PM
snrusnak's Avatar
Rep:1385
Wow that's very very close to TOO HOT! Be careful getting it that hot.
Mine was getting to like 215. Mine took an additional ~1/4 gallon the next day. And maybe a half a cup the day after(almost nothing).
Sean
Old 03-17-2012, 01:36 AM
07HemiRam's Avatar
07HemiRam 07HemiRam is offline
Vehicle: 2007 Dodge Ram
Trim Level: Quad Cab
Rep:17
07HemiRam is on a distinguished road
I want to do a 180* tstat swap too. What brand of tstat do you guys recommend?? Also want to flush out the whole cooling system but haven't done this. How do I flush out the system & what do I do with the old coolant??
6000K Bi-Xenon Headlights, 8000K Xenon Fog lights, Superchips Flashpaq, Magnaflow cat-back exhaust, Flowmaster y-pipe, Composite BFI with Amsoil dry filter, Flex-a-lite electric fan, 180* JET thermostat, 85mm Fastman throttle body.
Old 03-17-2012, 03:55 AM
Glenn B's Avatar
Glenn B Glenn B is offline
Vehicle: 2012 Dodge Ram 1500 CC
Color: True Blue Pearl
Glenn B is on a distinguished road
I used the JET-10183 (180*)
It seems to have a good reputation online among users.
JBA Shorty Headers, Jet 180* Stat, Airaid CAI, Mufflex 24"
Old 03-17-2012, 01:35 PM
chefred112's Avatar
Rep:656
you want to try find a tstat that has the blocker...it helps the engine warm up faster, some of the 180's out there can throw a p0128? (too cold) code. I use the autozone 4128
