Old 03-06-2012, 04:12 PM
johel77 johel77 is offline
Vehicle: 1996 Dodge Ram 4x4 5.9 auto.
johel77 is on a distinguished road
Talking No start, changed ECU bad again?
Ram 1500, 5.9, 4x4, Auto.
It started long time ago where it would shut off at about half hr. after starting and it wouldn't start back again until I let it coold for a while. Then scalated to cranck but no start, changed CPS on bellhousing of tranny & then TPS, nothing. Changed pick up coil under distributor cap, that fixed it for a while, then again same problem, it would crank but no start. Changed another pick up coil...nothing. So I changed ECU, it work again for a while, runnin smooth, after about a month, I'm where I started...cranck but no start.
Some things I tried:
Fuel pump is working fine.
Tried some starting fluid, nothing.
ASD relay tested good.
Coil has a yellow spark but readings are: 1.3 & 13.18
I should note that the first time it wouldn't start after I changed the ECU and it was running smooth, at crank it seemed like it was going to start but a big pufff stalling noise came from under the hood, after that it only cranks.
Any help would be greately appreciated.
Johel.
Old 03-06-2012, 05:21 PM
Rep:2616
If you can get your vehicle Smog excepted, do to high cost to repair
Pick up a manifold from a Magnum 360, that uses a carburetor & go old school pre computerized
If you have a Standard Transmission, it works especially well
A friend of mine tried several rebuilt/reconditioned computers & finally just gave up & sold his dodge truck for junk, he didn't even think about going old school, until i mentioned it too late, he had a stick shift
Old 03-06-2012, 11:49 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
You are going thru the same shotgun troubleshooting checklist I did about 5 years ago, turned out that I had an intermittent fuel pump. hook a gauge up to the rail connection. 40 psi and rock solid, under all driving conditions, it took driving 85 miles for it to act up, with the gauge stuck beneath a wiper, saw the flux, finally, and after r2'ing the pump, have never experienced that pit of the stomach ugly feeling of motor dying for un known reasons, again. ( tho it never actually died, just acted deathly ill, off and on)...
cps, ecm, ecu, no start, tps
