Old 03-06-2012, 06:21 PM
dodgeman9859L dodgeman9859L is offline
Vehicle: 1998 Ram 2500
Trim Level: SLT 4x4 QC
Color: Dark Red
dodgeman9859L is on a distinguished road
Default cant figure out whats wrong. pls help
My truck is a 98 2500 and its not throwing any codes but its got a constent hesitation going down the road. when its cold it wont do it at first and if i floor it it feels ok for the most part. dont believe its spark and like i said its not throwing a code. if anyone has experienced this or has an idea pls help and give me an idea. thanks everyone.
Old 03-06-2012, 06:41 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
First try cleaning the throttle body and the next thing I would do if that doesn't work is do a fuel pressure test. The pressure should check out at 43 PSI +/- 5 PSI. These EFI's are picky with pressure, I was once getting 35 PSI and it was so hesitant, it was an indication that my fuel pump was on it's last leg and it was when the truck backfired due to no fuel.
But just try cleaning the TB This sometimes help.
Old 03-06-2012, 06:47 PM
Color: Dark Red
Well the throttle body was just done. and its weird like i said when its cold it doesnt do it much but a few short minutes of driving it does it. mostly does it going a steady speed and it idles fine. going through gas like crazy tho too.
Old 03-06-2012, 09:06 PM
ramvan2500's Avatar
Rep:128
It sounds like maybe a Pre-Cat O2 sensor. These O2 sensors don't get accurate readings until they heat up to about 600F. So it's possible the O2 sensor is starting to go bad or it is already. It won't always throw a code which never helps, the only thing you could do is connect a specialized scan/diagnostics tool to get an exact answer. However that can be costly. For the sake of it check the fuel pressure anyways, it won't hurt to be sure. But yea I got a gut feeling it's an O2 sensor. With my luck you just replaced the Pre-Cat O2 Sensor.
Old 03-10-2012, 05:24 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Undo the precat sensor and hang it to the side so as not to bang it around and go for a drive and see what happens. It will be a little noisy but it wil check out your cat for you. If it runs fine with no problems then you have a cat going bad. If that doesn't change things pull you negative off your battery and go inside the truck and turn the key to start and then off 3 x and the reconnect the battery. This does a computer reset back to the base firmware and will correct some out to lunch reading that the computer can't get back in the right ballpark to run properly. Sometimes the computer will overrun it's calculations to a point that it can't recover and this will put it back to baseline. Good luck.
Old 03-19-2012, 01:22 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Do you smell raw fuel while idling? Thats usually a sign that the O2 sensors are shot.
Old 03-20-2012, 09:44 AM
dodge ghost dodge ghost is offline
Vehicle: 1995 Dodge Ram 2500
Trim Level: Ghost
Color: Flat Black
dodge ghost is on a distinguished road
I have a 95 Ram 2500... I was getting lack of power...I replaced the fuel injectors in it and the egr valve. Now I have my power back in the engine!! BIGTIME! Also, your engine may just have a vacuum leak...Run a vac test or smoke test to see if there is air escaping. What happened to me was that when driving and just trying to maintain a speed between 40 and 50 the front end would shake and flutter...I originally thought it may be a wheel balance ordeal, but it wasnt. If the cat is going bad, the signs will be: When you try and accelerate, it will take you forever to gain speed, the internal material in the cat sometimes can go bad, breaking up inside causing your engine to be unable to breath basically---suffocating.. I have just went through this stuff with my truck, I replaced the cat and y-pipe assy, the egr valve, fuel injectors, O2 sensor(which you may as well do anyway if youre gonna replace the cat), and yesterday I replaced the valve cover gaskets...Hope this helps..
Old 03-20-2012, 09:51 AM
ramvan2500's Avatar
Rep:128
Wow new injectors, must of been pretty expensive. But hey happy you got it fixed, I usually keep my injectors clean. You're suppose to use fuel injector cleaner every 3000 miles but who really does that right...
My injectors are 16 and still injecting lol
