Old 02-04-2012, 12:39 AM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:94
Default Load D Rated Tires
any of you ever had, or heard of anyone having handling issues with load d rated tires ? mine are bfg 315's. Trying to get my death wobble under contol..some say the sidewalls are to thin and need the E rated. any feed back would be appreciated
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter, SuperChips Flashpaq 3482
Old 03-08-2012, 12:17 PM
Platypusfetch's Avatar
Platypusfetch Platypusfetch is offline
Vehicle: 2007 Dodge Ram 1500 Mega Cab
Color: BLACK
Platypusfetch is on a distinguished road
Hey!
I am Running 285/70/R17's BFG's on my Megacab.... Load rated "D". My "Death wobble was not caused by the tires, but by the steering damper which had sprung a leak. Installed the Dodge Replacement for just under $200 CAN. From what I researched, it is caused more likely than not by a worn suspension part (Ball Joints/tie rods/trailing arm bushing/steering damper) than by the load rating of the tire....However, running that size.... there is a lot of weight rotating around.... is your Ram lifted? That seems to be an issue sometimes as well ( maybe due to the truck not being biased enough weight wise on the front end....)
