Old 01-27-2012, 09:39 PM
Detail's Avatar
Detail Detail is offline
Vehicle: 2012 QC Express 4x4
Color: Deep Cherry Red
Rep:31
Detail is on a distinguished road
Default Yes, another de-badging thread...the less mess edition! (with pics)
washed my rig and parked it inside just in time for the big storm, decided to take the day off and spend some time playing. Been wanting to debadge this thing since the day i brought it home a month ago. whole job took about 2 hours, taking my time, including tailgate.
Before.... no kidding
mmy weapon of choice....heated up each letter individually, takes about 30 seconds a piece on low to get them loose enough to slide the sharpened paintstick behind as mentioned by AzHunter here- http://ramforumz.com/showthread.php?t=92968 the heat gun makes the job very easy.
this is what you're left with if everything goes right....just the adhesive. As you can see the bottom edges have been rolled up, thats what the paintstick does. Now, alot of guys are using rubber erase wheels or trying to scrape the adhesive off with the paintstick....STOP! take a break, let the adhesive cool down to room temp, now with your fingers start picking and pullin g at the opposite end of where you pushed the paintstick under....if you try the same spot it will be extremely difficult as the paintstick and heat smear the adhesive.
Heres what happens if you wait for it to cool.....very easy removal. Please excuse the busted thumb
No thanks on the eraser wheel
this is what you're left with....a little bit of adhesive that was smeared by the stick, and probably a little dirt thats been underneath there for god knows how long.
this is where a little bit of solvent will come in handy, use whatever you want, this is what i use at my shop so its what i used here. any wax and grease remover will do, or goo gone if youre into that greasy orangey garbage.
I use scotts shop towels on a roll for everything, worked great for this job, gentle on the paint but strong enough to pick up the adhesive without scratching. I actually went over the sticky spots with a pretty heavy amount and let it soak in first so i didnt have to scrub the paint and possibly scratch it
Voila....make sure to take a minute and give the area a coat of wax, unprotected paint is unhappy paint.
then play with your letters obviously
dont forget the tailgate.....and get rid of that dealership sticker while you're at it.
There you have it....the less mess edition
Old 01-28-2012, 12:08 AM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
looks much better, always nice to see a little bit different way of doing it (letting it cool in this case) I have been up in the air about doing my truck, I think I am going to leave it.... the dealer badge on mine was "etched" into the tail gate or something to that effect, but has faded off and only part of it shows, so maybe I will tackle that... my parents 08 has pretty big badges above where the Hemi badge is, 1 on each side
Old 01-28-2012, 12:40 AM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
6.4L HEMI Driver
Vehicle: 2014 Ram 2500 CC 6.4L HEMI
Rep:93
ShiftJockey will become famous soon enough
Good info there. Who makes that Pro-Sol stuff?
Michael
2014 BIG HORN CREW
6.4L HEMI
Old 01-28-2012, 09:25 AM
Detail's Avatar
Rep:31
thanks guys. Pro-sol is made by Pro Car Beauty. they make a wide variety of detailing and body shop products, i use alot of their stuff at my shop, i actually waxed the areas where i wiped the pro sol with their pro gold wax afterwards. Probably the easiest wax to apply and remove that ive ever used.
Old 03-07-2012, 02:07 PM
abadiechris abadiechris is offline
Vehicle: 2012 Dodge Ram
abadiechris is on a distinguished road
should have read this before i did mine last night. it took way too long.
