tonneaucovered.com
Old 03-07-2012, 02:23 AM
Alaskan Hemisport Alaskan Hemisport is offline
Vehicle: 2011 Ram 1500
Alaskan Hemisport is on a distinguished road
Default Replace the Cats?
So this could be a stupid question, but I had an idea. If I had an exhaust shop replace the mid pipes that had the stock cats with straight pipes, would I see a hp/mpg gain?
Also, I know that when you get LT that there is CEL problems, if you had the stock 02 sensors installed in this new straight pipe, just as they would be set up in the stock pipe, would you still have problems?
Finally, would removing your cats cause any kinda problem as far as making the motor run too rich or lean?
Old 03-13-2012, 04:04 AM
monkeii21's Avatar
monkeii21 monkeii21 is offline
Vehicle: 2007 dodge ram
Trim Level: lonestar
Color: flame red
monkeii21 is on a distinguished road
I think removing the cats would rob your low end power due to no back pressure I would just go with some hi-flows
Old 03-13-2012, 02:16 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
there would be a performance change as the flow would be more unrestrictive (just don't straight pipe all the way through (have a muffler). this should also improve gas mileage (it did for me)
you would still need to do the plug fouler mod which pulls the o2 sensor out of the jetway and stuff steel wool in it.
Old 03-13-2012, 02:23 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
Looks pretty ingenius.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 03-19-2012, 02:23 AM
86bcook's Avatar
86bcook 86bcook is offline
Vehicle: 05 Dodge Ram Hemi
86bcook is on a distinguished road
so you stuff steel wool between the two foolers?
Old 03-19-2012, 04:31 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
I added 0000 wool to my non foulers and cats code free for 20k+ miles.
Old 04-24-2012, 07:32 PM
Danzanzio's Avatar
Danzanzio Danzanzio is offline
Vehicle: '05 Dodge Ram
Color: Atlantic Blue
Rep:86
Danzanzio will become famous soon enough
I understand I'd have to do this mod for both of my cats but would i have to do it for both plugs on each cat? It looks like i have one before and after on my cats.
Old 04-26-2012, 10:33 AM
Color: Satin Orange
Rep:627
just both rear 02's.
Old 04-28-2012, 10:29 AM
chefred112's Avatar
Rep:656
agreed, rear only..you will jack up your motor if you do this on the front o2 sensors..
Old 04-28-2012, 02:46 PM
Danzanzio's Avatar
Rep:86
lol that's what I thought. But just wanted to make sure.
