Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 03-07-2012, 06:14 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Default How is your oil color when you change it?
I just changed the oil in my 5.7 Hemi. for the first time at 1500 miles. I wanted to get that first one done early because I always think it's the 'break in' oil run and I want to get it out after I feel the initial break in is complete.
I was concerned though when I saw the oil I drained out of it was very dark - I mean Black!
On all other new cars I've owned, the first oil change was always still like dark Honey....
I will say, I ran the motor pretty hard and towed 10K for about 400 miles.... what are you guys seeing? Is this normal for the Hemi.?
Old 03-07-2012, 09:36 PM
I push the skinny pedal
Rep:3277
My oil gets very dark over time, but I run my royal purple up to 15,000kms normally if I can't get an analysis done.
Kurtis
Old 03-07-2012, 09:43 PM
ksolt's Avatar
ksolt ksolt is offline
Vehicle: 2002 dodge ram
ksolt is on a distinguished road
Its normal. Doesn't take long to turn black.
Old 03-08-2012, 04:14 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I changed mine at 500 mi from habbit of breaking in the street motors for the camaro and it was as black as satans soul
2011 Big Horn 4x4 -SnowWhite-
Old 03-08-2012, 07:48 AM
Bikenut's Avatar
Rep:73
Ok cool, I guess it's normal for this engine
I dont know if it was placebo effect but I swear the engine feels smoother and quieter after the oil change.
Old 03-08-2012, 08:18 AM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
my first change, the oil came out pretty dark, looked like m1.
Old 03-08-2012, 10:15 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
It is completely normal for oil to look black even a few hundred miles after an oil change. Modern oils do a better job of cleaning and trapping oxidized oil, soot, micro particles etc. than older oils and that is what turns the oil black.
Old 03-15-2012, 09:43 PM
tuc0007 tuc0007 is offline
Vehicle: 97 ram 318
tuc0007 is on a distinguished road
Talk is cheap; my dodge has black oil every oil change i have seen other makes and modles right up to 2007 and there oil is like honey. i have a 97 1500 ram and use Mobile synthetic oil 10w and it is black every time i change it approximently 5000k it also burns the oil about a liter every change
Old 03-21-2012, 10:41 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
You'd better hope your oil is coming out dark when you change it...unless you're changing it every other day. That darkness is not a problem with your engine. That's your oil working to loosen and suspend all manner of deposits that are trying to stick to the colder parts of your engine's interior. It's not only normal, it's required. I remember in the "old days" when people still ran non-detergent motor oils. I worked as a kid part time as a mechanic's apprentice during high school at a dealership. Some customers were very adamant about running a specific oil in their engines upon us doing any engine work, because they bragged about how clean this or that particular oil was upon the oil change. Those folks thought this was a good thing. When you opened up that engine, it would invariably have a scary layer of sludge built up on the bottom of the oil pan and stuck to the top of the valve cover(s). But yes...the oil looked like it came right out of the can...LOL!
