Old 03-07-2012, 11:58 PM
andrewheringer12 andrewheringer12 is offline
Vehicle: Unknown
andrewheringer12 is on a distinguished road
Default What Ram do you recommend?!?!
Hey everyone!
My name's Andrew and I'm currently a Dodge Dakota owner. I am going to be upgrading to a Ram, either 1500 or 2500, I just can't really decide. This is where you come in! I've done some research and don't want a diesel anymore. I'm wanting gas engine for sure, either 5.7 or 5.9. If you guys could reply with your findings, experiences or any other knowledge you have about the engines(hemi/MDS hemi/magnum), drive trains, suspensions(live axle/IFS) or anything else to help me make a decision on my new truck, it would help a bunch!
To keep in mind, I do my own work on my truck and love Wheelin'!
Cheers!
Old 03-08-2012, 12:33 AM
Rep:2640
Welcome to this RamforumZ
gasoline engines now are the 6 cylinder, i think 3.7 L
small 8 cylinder 4.7L about 318 size
Hemi 5.7L
Then the diesel
the 5.7L is in the 1500, 2500 & 3500 series, the 1500 has MDS, it cuts down to 4 cylinders when horse power is not needed, it can be bad or good, depending on how you use the truck
The 1500 has a car like ride with coil springs
the others have leaf springs & are a REAL use truck
The 1500 has a light use transmission
The rear ends available are
3.21 ratio, best gas mileage, would be ok if you only pull or haul stuff under a ton
3.55 ratio with or without LSD, fair mileage, a little bit better for towing & hauling
3.92 ratio with or without LSD, a bit less MPG, much better for towing/hauling, most recommended ratio with LSD
4.11 ratio less mileage again, great for pulling heavier loads
Get the tow package, no matter which model & rear end ratio that you decide to get, it gives you the heavy duty radiator, & other very useful advantages
I suggest that you don't get a Ram with the RES radio, it is the Base model radio
The 3 letters will be on the radios face, lower right bottom corner
Good Luck & keep researching
Old 03-08-2012, 12:57 AM
pagan pagan is offline
Vehicle: 2012 ram express
Trim Level: EXPRESS reg cab
pagan is on a distinguished road
I highly recommend getting a regular cab short bed outdoorsman, as long as u don't need room for more then 3 passengers (most people want it but don't need it) and u don't need an 8 foot bed (again most people don't) then this truck should satisfy all ur needs, it'll tow 10,000 lbs, its a little faster than a crew cab since it weighs atleast 600 pounds less, its also available with nearly every other option including hemi 5.7 alpine system nam power seats etc. bit if u can do without all the extras than get the express or tradesman, they're probly the best deals in full size trucks today. I have a 2012 express.
Old 03-08-2012, 08:22 AM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i wanted a 2500, but bought a sport 1500. my truck is a toy and i couldn't justify the extre coin for the 2500.
Old 03-08-2012, 09:18 AM
letsjet's Avatar
letsjet letsjet is offline
Vehicle: 2014 Ram 1500 Express 5.7L 4x4
Trim Level: EXPRESS
Color: FLAME RED
Rep:27
letsjet is on a distinguished road
I had a 97 regular cab, a 2007 hemi quad cab, and now an 05 4.7 regular cab again, all 1500's. I'm looking for another quad cab, those back seats come in handy and now that I'm married I got dogs. A short bed regular cab with a leer shell is really pratical, otherwise I need the quad. You can't go wrong with a 1500 quad 5.7 hemi, the 4.7 is a pretty strong engine also, mpg is about the same. Oh yeah the quad seems like twice the truck than the regular cab when you wash it.
2014 Ram 1500 Express 5.7L Quad Cab 4 X 4 Flame Red
2010 Dodge Challenger R/T Hemi Orange Pearlcoat
2010 Dodge Challenger R/T Classic Furious Fuchsia 6 spd
Old 03-08-2012, 09:40 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Are you looking at used or new? As said the new engines are the v6, the 4.7L v8, and the 5.7L Hemi v8. Personally if you use it for anything at all more than a daily driver, to and from work, and want it to have some oomph get at least the 4.7L. The 4.7L is fairly strong, I like mine. If you want to race or whatever then get the hemi. All the engines are great and reliable.
If you are looking at used, I'd definitely get the 5.7L over the 5.9L. The hemi will get better mpg, it is more reliable, and has way more power.
Sean
Old 03-08-2012, 09:42 AM
snrusnak's Avatar
Rep:1385
Also, if you didn't know, the 4.7L was changed in 2008 and the older version was 235hp 295lbft, the newer version is 310hp 330lb ft. It's a pretty significant difference. The 5.7L hemi was also changed around 2009 I think, the old version was 345hp 375ish lbft, the new version is 390hp 410lbft.
Sean
Old 03-08-2012, 10:00 AM
roadrnnr's Avatar
roadrnnr roadrnnr is offline
Vehicle: 2011 Ram SLT
Color: Rugged Brown
roadrnnr is on a distinguished road
I wanted a big horn but could not find one at the time, but now my SLT is the way I wanted whatever I got so I am Happy
road................
Old 03-08-2012, 10:18 AM
3mains's Avatar
3mains 3mains is offline
Vehicle: 2010 Dodge Ram Crew
Trim Level: SLT Crew
3mains is on a distinguished road
I would recommend the 1500 crew with the HEMI 5.7! I purchased mine after a lot of research and test drives. It has more hp than any stock truck I have driven and better handling. I also have the tow package and wouldn't recommend purchasing one without it!
Hello everyone! I am another newbie! Just purchased my first Dodge Ram and I am glad I did!
Old 03-08-2012, 10:21 AM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
I got the 2500 for these reasons:
I need to tow 10K. I mean comfortably within the capacity of the truck, not at the limit.
I wanted the Mega Cab with the 6.5' bed
I wanted a solid front axle 4x4 (Hated my IFS 4x4 previously -weak)
I believe the truck will be longer lasting with stronger parts throughout
HUGE Brakes!
The cost of the 2500 was negligible considering the overall price tag
The ride quality of my 2500 is Fantastic (compared to my 04' duramax)
I came from diesel to the Hemi. also and have been very content with the capability of this motor
