Old 03-08-2012, 04:39 PM
Mikeaob's Avatar
Mikeaob Mikeaob is offline
Vehicle: 2012 Ram Express
Mikeaob is on a distinguished road
Default Wheel Offset Question ??
I am looking at the 20x9 ballistic jester with 33x12.50 20 mud terrains.. The wheel offset says +00 mm Im not farmiliar with offset measurements. I will be raising the front 2.5 inches to level it.. It is a 2012 Ram Express Quad cab in Black
Any thoughts on the +00mm offset ?? How it will look ? or pics
Old 03-09-2012, 05:45 AM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
a negative offset will bring the wheel out of the wheel well farther .positive will tuck it under the wheel well. factory wheels have positive offset. since the jester is 0 offest it will come out a little farther than stock but shouldnt be too bad.
Old 03-09-2012, 09:27 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Those wheels will fit good (about 1/2" out from the stock wheels) and give you extra clearance between the tires and suspension.
A -0- offset means that the mounting surface is centered between the inner and outer wheel edges. Like mentioned prior, A + offset (say +20mm) will move the mounting surface towards the outer edge of the wheel (thus pulling wheel towards the truck) and a - offset (say -20mm) will move the mounting surface towards the inner edge of the wheel (thus pushing it out).
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 03-09-2012, 05:11 PM
Mikeaob's Avatar
Thanks for the Reply's . I want them to stick out a little further than the stock..
Old 03-09-2012, 06:19 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
That should work great for you. As they said that offset will stick out a little more than stock just like you want. You actually probably need that extra clearance to fit the 12.50s.
