Old 03-08-2012, 06:23 PM
1500ram12's Avatar
1500ram12 1500ram12 is offline
Vehicle: 2010 Dodge ram
Rep:81
Default mopar fog light kit
I've searched everywhere for an answer and haven't found it yet, that I know of. I am getting ready to install the mopar fog light kit in my 2012 SLT. Depending on where you look the kit list either 2009-2010 or 2009 and up. The only problem is the wiring directions only work for 2009-2010. Dodge decided to change the wiring up. What I've found after hours of searching and talking to local dearlers is that the wiring harness for the fogs is suppose to go in the grey connector in slot 11/16. unfortunately their is a wire in 16 and I cant locate 11. Has anyone had any luck installing these on a 2011 or more importantly a 2012 because I have a feeling dodge changed the locations for 2012. I don't have the kit yet so I cant try anything yet. I'm just trying to figure as much out now so when install time comes it will hopefully go as easy as it can. I already have the switch and sales code installed. Any help and pics of the tipm/connector would be greatly appreciated.
2010 Ram 2500 SLT 6.7L Cummins, S&B CAI, H&S Mini Maxx Race Tuner, DPF Delete, EGR Delete, Bilstein 5100's, raceland 4" e-cutout
Old 03-09-2012, 12:28 AM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
I just checked and the 2011 and 2012 wires are in the same locations 11 and 16 in the light grey plug.
Old 03-09-2012, 06:19 AM
1500ram12's Avatar
Rep:81
thanks for the pic. but the connector directly below where the fuse is for the fogs doesn't look like that. Hopefully I'll get a chance to look again today and see if I can find a connector that looks like that.
Old 03-14-2012, 04:35 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Are you referring to the Lt. Gray connector on the bottom of the TIPM? Connector C4 (Often labeled 'D') ?
brad
Interested in one of my mods?
Old 03-14-2012, 08:46 AM
1500ram12's Avatar
Rep:81
yeah, I still haven't had a chance to hook it up yet, hopefully today. the problem I had was I was looking at the connector directly under where the fuse is for the fogs. I found c4 and 11/16 are open so if those are the right ones I should find out today.
Old 03-15-2012, 01:42 AM
brad12kx's Avatar
Rep:2581
If C4 on your truck has no wires to 11 and 16, then the wiring DID change for 2011/12. I really need to find an updated wiring diagram. Mine covers 09/10, and I have found quite a few discrepancies in the newer trucks, so can't offer any help this case.
brad
Old 03-15-2012, 10:21 AM
1500ram12's Avatar
Rep:81
here is a link that covers all the wiring for the ram trucks. It did help and I do have the fogs hooked up and working without any problems. took about 5 min to hook the wiring harness up then the lights fired right up
https://techauthorityonlinedemo.extr...ew/classic.htm
Old 03-15-2012, 11:19 AM
brad12kx's Avatar
Rep:2581
That is an excellent link! It clearly shows that D11 and D16 on C4 are the correct terminals on the 2012.
Did you need to get the dealer to add an option code to bring the fog lights functional?
brad
Old 03-15-2012, 01:41 PM
1500ram12's Avatar
Rep:81
yeah the sales code is LNJ I think. I've read that some dealers are charging up to $80 just to add the code. Didn't cost me a thing. But I do a decent amount of business through them.
Old 03-15-2012, 01:44 PM
1500ram12's Avatar
Rep:81
heres a couple of pics, I should add that I changed my mind on using the mopar fogs and bought some hella micro FF to use instead but used the wiring harness that came with the kit. It did take some slight persuasion and a cut of the bumper bracket to get the lights to point up enough to get them aimed right. I do plan on cutting the plastic piece to fit around the lights to fill in the gaps
