Old 03-08-2012, 06:56 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
Default What to do to truck before long trip?
So I will be heading from New Jersey to Florida this May to move down there, and I was wondering besides a oil change what else do you guys recommend me to do to my Ram before I take this long journey?
Old 03-08-2012, 07:32 PM
welr welr is offline
Vehicle: 2011 Dodge Ram
Color: Gray / Sandstone
welr is on a distinguished road
I do it just like I do a haul tuck at work.Start at the engine check engine oil, ATF, power steering, air filter, antifreeze resivor, and washer fluid and wiper blades. Don't forget to check for cracks and splits in the serpentine belt. Next start at left front tire and work your way around the truck checking the tires (valve stem's, tread, and sidewalls especialy along the rims) also check the lugnuts and brake pads and rotors. Next turn on the lights and hazard's and walk around the truck to make sure there all working. Don't forget to check the horn. Also check diferentials, axel seals, and tail shaft on transfercase for leaks. I do that before every 1700 mile trip back east. Sure takes a lot of worry out of the drive.
Old 03-08-2012, 08:10 PM
Trim Level: sport
Color: green
Rep:670
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
also check hoses. i actually change the oil before along trip, same as you, nj to florida. bring a couple of quarts with you.
Old 03-08-2012, 09:29 PM
fat1's Avatar
fat1 fat1 is offline
Vehicle: 2015 Dodge Ram 1500 Sport CC
Rep:15
fat1 is on a distinguished road
renew your roadside assistance plan, get in and drive
Old 03-09-2012, 12:35 AM
Rep:2664
I do the usually check of fluid levels
& wear parts, belts, hoses, tires
Look in your local coupon book for a free brake inspection
Fill up the gas tank & drive safely
Old 03-09-2012, 12:52 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
Im doing a 10hour drive to charlotte n.c then a 7hour to outter banks in about a week i did new atf less than 10k ago im going to do all the checks everyone else said plus new front pads/rotors diff fluid change and an oil change
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 03-09-2012, 09:26 AM
RamManCan RamManCan is offline
Vehicle: 2010 Ram
RamManCan is on a distinguished road
Doesn't hurt to check you spare tire for proper inflation, and make sure the unit that holds it in place isn't ceased. You'd be suprised how fast they can lock up and then your spare is useless, it happened to one of our work trucks along side the road...really sucked. Without tools(B.F.H., pry bars...) it would have been impossible to get the spare out, luckily we had those avaliable.
Old 03-09-2012, 09:36 AM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
I used to run my 04 Ram 1500 QC 4wd with the 4.7 back and forth from Maine to Seminole Florida and I can tell ya not alot to do but have a GPS thats up to date and all your pre flight checks done as Welr described. I had Good Sam Club and AAA . It really takes all the worry off the trip. Then get out there and drive
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 03-09-2012, 10:14 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Put gas in it.
Seriously....check all fluids, tires, maybe crawl around underneath the truck and under the hood just to look for anything that looks "not right". Other than that, bring a bag of emergency items (qt of oil, gallon of water, duct tape, flash light, small tool kit, zip ties, hair bands, hair clips, chewing gum, belt, rope, etc...)
It's amazing how far you can limp a vehicle with women's clothing accessories...
Sean
Old 03-10-2012, 11:38 AM
Rep:25
Thanks everyone I will have to do all of that before I do this trip!
Huntergreen, you know around about how much you spent on gas for the trip to fl?
