United Radio
Old 03-09-2012, 01:24 AM
kombucha20's Avatar
kombucha20 kombucha20 is offline
Vehicle: 2005 Dodge Ram 1500 Hemi 5.7
Color: grey
kombucha20 is on a distinguished road
Default Exhaust question
ok so im gonna try to explain this the best i can
so right now i have http://www.magnaflow.com/02product/s...ne=all&id=3271
so im assuming i would still have my stock catalytic converter??
im planning on installing LT headers soon
so would i leave everything the way it is or would i use somththing like this
http://www.magnaflow.com/02catalytic...irectfit=49597
i know im probably not explain this very good, sorry
05Ram Hemi 4x4,K&N CAI,Magnaflow duel exhaust,SC Programer, srt10 hood
Old 03-09-2012, 12:23 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
To connect long tubes to the rest of the exhaust you will need a shop to custom bend the pipe to fit and weld it in.
Sean
Old 03-09-2012, 02:32 PM
chefred112's Avatar
Rep:656
the cats have to be moved regardless with LT's...mine had to be moved rearward..of course they are empty anyways but just in case i get popped by popo, it looks like the cats are there..
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 03-09-2012, 02:36 PM
chefred112's Avatar
Rep:656
that second link you posted won't be direct fit for lts...need to have exhaust guy custom fit for you...
Old 03-09-2012, 07:19 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
You should be able to buy or the headers should come with a matched mid/merge pipe. Ive never seen companies offer headers without something to get them out of the engine bay and just cut your stock i pipe to length and attatch it to your magnaflow. Thats what i did when i was running my Corsa
2011 Big Horn 4x4 -SnowWhite-
Old 03-14-2012, 07:47 AM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Don't you need Some back pressure on naturally aspired gas engines?
Old 03-14-2012, 09:40 AM
snrusnak's Avatar
Rep:1385
That is not true. It is a common misconception. Back pressure is always bad for exhaust flow and power potential. What often hurts power is having reduced exhaust gas velocity, by having too large of a pipe diameter. The smaller the diameter, the faster the gas flows through it. High exhaust gas velocity is desirable as it helps scavenging. The oem size pipes (2.5" off the manifolds, 3" at the merge, and if you have oem duals then 2.25" tailpipes) are about perfect for what you'd want on a stock to fairly modified engine. If you have extensive mods you could probably go 3" the whole way.
Basically back pressure is always bad, and there is a limit of too small and too big of exhaust pipe diameter. Many people confuse the two, thinking back pressure somehow helps power potential.
Sean
Old 03-14-2012, 10:55 PM
Bikenut's Avatar
Rep:73
Thanks for that, but I was thinking in terms of Torque???? Dont you loose torque, especially at he lower RPMs with too much flow?
I like what you're saying though, it seems to make sense..
Old 03-14-2012, 11:27 PM
snrusnak's Avatar
Rep:1385
^No, you'll make more power and torque at all rpm's with a more free flowing (but properly sized) exhaust.
The gains at lower rpm's may be minimal, however.
Sean
