Velocity Stack? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
Diesel Forums!
Dodge Caliber
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 03-11-2012, 11:54 AM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
Default Velocity Stack?
Yeah I was looking around on ebay and was checking out these velocity stacks, says it adds hp blah blah blah. Sorry I don't know enough about computers otherwise I would have put a link to the page. What are these velocity stacks anyway? To me it just looks like another type of tb spacer.
Old 03-11-2012, 02:21 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:235
Save your money, its not going to help. In the old days with a carb, maybe they helped a little bit.
Old 03-11-2012, 02:23 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:782
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
thats what i was going to say, don't see it works with fuel injection and all our electronics.
Old 03-13-2012, 01:48 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
They work good on 300/400hp outboard Mercs strapped to a 20' Allison Sport.
Old 03-13-2012, 02:01 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Usually they will help a little with higher rpm's. They help smooth the airflow a little. Very minor difference usually, and on a street engine that see's lower rpm's, even less of a difference. Probably not worth it.
Sean
Old 03-13-2012, 07:12 PM
Rep:3347
A velocity stack is basicallu a bernouli bell mouth, it's designed to allow the flow of air to pass from an infinately large reservoir into a circular opening while maintaining laminar flow characteristics. This allows for a large flow of air to pass through the opening, increasing velocity, while maintaining laminar (smooth) flow of air. In our case, you would get a smooth flow of air into the intake manifold, and then you'd destroy that flow of air as it's broken into 8 separate streams that are pulled through the intake runners.
Put this in the same category as throttle body spacers. People believe a throttle body spacer does something special by swirling the air as it passes into the intak manifold... and then it's destroyed as it breaks into the 8 intake runners. The only place you see any benefit with velocity stacks is if you are running turbos and don't want a filter, or if you are running 2x 4bbl carbs and you have a stack for each barrel of the carb.
