Old 03-11-2012, 04:53 PM
djbaselle djbaselle is offline
Vehicle: 2012 DODGE RAM
Color: BLACK
djbaselle is on a distinguished road
Wink PLS help with power
My system chipped out on me yesterday. Does anyone know where the fuse is for the radio? i can't understand the fuse for crap. Does any know any other reason why i my radio isn't power?
thanks in advance
Old 03-11-2012, 05:57 PM
337ram 337ram is offline
Vehicle: 2009 1500 4x4
Color: grey
Rep:15
337ram is on a distinguished road
What were you doing etc when you radio quit playing???? Is it all stock radio system??? The fuse should be loacted under the hood driver side close to front in black box
Old 03-11-2012, 06:20 PM
Color: BLACK
No i don't have a stock radio. i was installing an amp it was all working fine then i was hiding all the wires and it cut out! No amps or radio is firing up and the 30 amp fuse is still good..All my remote wires have no power..
i have no idea what it could be if the fuse is good
Old 03-11-2012, 06:23 PM
Color: BLACK
I'm running pioneer avic 1130bt and 2 amps.. the remote feed was ran from behind the radio so I'm not receiving any signal to anything
Old 03-11-2012, 11:53 PM
Color: grey
Rep:15
If the head unit was already installed before the amps, more than likely you either pinched your amp power wire, scraped shield off or something ..............Pull head unit you should have a fuse in back of it, if so replace , BUT BEFORE that pull your fuse on your power wire leading to amps
Old 03-13-2012, 12:30 AM
Color: BLACK
is there a fuse for the acc red wire? bc I'm not getting a signal from it. IM running the pac C2R-CHY4
Old 03-13-2012, 01:51 PM
Color: grey
Rep:15
Man if you checked all your fuses, and your POSITIVE you have no power coming from harness you might be screwed, maybe needing to take it to dealer IDK. One thing you can do is pull that stupid PAC adapter, run your power for head unit down to your power outlet, the front driver side cigerette/power outlet, it is switched, tap in there for power, and then do tie your radio in old school into existing speaker wires, by passing the radio circuits +- from truck. IF YOU DO THIS, REMOVE all power to your amp, somehow imo you did something wrong there and thats where your problems started
