Shift points...... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Diesel Forums!
Dodge Caliber
Old 11-16-2016, 12:43 AM
striker2237's Avatar
striker2237 striker2237 is offline
Vehicle: 2003 Ram Laramie 4x4 3.55 LSD
Trim Level: 6.7L/408CI+NOVI 2000
Color: Bright Metalic Silver
Rep:167
striker2237 has a spectacular aura aboutstriker2237 has a spectacular aura about
Default Shift points......
So. Assuming a 6200 rpm max and about a 1500 rpm "fall" after a shift when would you suggest I should set the shift points for best acceleration?
Mods: OEM tonneau cover+bug deflector+bedliner+floormats+hitch light+fuel door, Stubby antenna, 900CA AGM battery, Silverstar lights, Front window tint, Cabin filter, Bilstein 4600s, Kicker stage 1, Rear wheel liners, Mopar valve covers+breather, Pacesetter wrapped headers, Custom midpipe, Magnaflow X-pipe+custom axleback, SSBC front brakes+Powerstop rear, Moog front suspension+hubs, Maval custom rack, Borgeson steering shaft, Stainless steel brake lines, Hellwig front/rear sway bars, Poly bushings, Custom springs, Hydroboost
1989 W150 transmission shift points too high hottrodscars 5.2L V8 Specific Topics 1 08-07-2014 08:57 AM
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Edge CTS Ram Engine Codes Asur 4.7L (287 cu in) PowerTech V8 Specific Topics 5 11-16-2013 10:55 AM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
shift points liljohn30 Diablo Predator Questions & Info! 2 09-06-2010 08:09 PM
