Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 03-22-2012, 10:20 PM
Hemi Joe Hemi Joe is offline
Vehicle: 2012 Regular Cab Hemi Express
Trim Level: Regular Cab Express
Hemi Joe is on a distinguished road
4x4 is about 300 pounds heavier, so 3 tenths slower.
Every hundred pounds = 1 tenth.
Not to worry though I turned my 10' RCSB 4x4 with 3.55's into a 13 second beast with just intake, exhaust, tires and a tune.
Thanks for the info. It's impressive what these trucks can do. I can't wait until I can get a tuner for a 2012.
As a sidenote, I wonder how much drag the front differential and front driveshaft spinning all the time causes. Wish they came with manual hubs.
Old 03-22-2012, 11:38 PM
roo roo is offline
Vehicle: 2013Express,2014 Charger R/T
Rep:39
roo is on a distinguished road
Yes it does, I've got video to prove it
Hey man, I think I figured out whats goin on here. On a 2012 if you select 3rd on the trans stick you will get
1st 3.00
2nd 1.67 and 3rd 1.50.
The difference between 2nd and 3rd is about 10 mph. Using the calculations with 10% converter slip that would give you 87 in 2nd and 97 in 3rd. Correct me if I'm wrong but on a 10 or 11 Ram you can only access 2nd 1.50 only on a down shift (passing gear). So yes you would have been shifting to you're 3rd (my 4th) at about 87 mph well before the end of the 1/4 mile.
Old 03-22-2012, 11:49 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^Pretty sure both the 545rfe and the "new" transmission operate the same. I can upshift to 2nd prime (1.5) by selecting it manually in the ERS (electronic range selection) on the shifter.
Sean
Old 03-23-2012, 12:03 AM
roo roo is offline
Rep:39
I think if you wind it out (5800) in 2nd in my truck it will skip 3rd/1.5/2nd prime and go straight to 4th. But if you select 3rd (while in 2nd) well before redline it will grab 3rd/2nd prime. It really pulls nice after the shift, too bad it doesn't get another 5 mph or so out of it.
Old 03-23-2012, 12:23 AM
BlackRamHemi's Avatar
BlackRamHemi BlackRamHemi is online now
Vehicle: 2010 Ram RCSB 4x4
Rep:554
I used to use manual mode (or Tow/Haul mode) to catch the 2nd prime up shift,
Have since found out its BAD , and one of the weakest links in Dodge transmissions.
3G guys who race will tell you to avoid it at all cost if you want your trans to last.
I now just run 1-2-3, ET's are the same but my trap speed is down slightly now.
I'll bet I'll pick that back up with some more HP and headers next time out.
I track test the crap out of everything I do to my truck,
Have well over 200 passes in the last 2 years on her now.
and when the track is closed I use a back country road and my tuners
Here's an old vid, testing with my old BullyDog using 2nd prime
here's another...
Quite a bit more power and shifting at 6400 rpm with a Diablo 93 tune now
Traction problems ...check out the 2nd gear chirp on this one
Old 03-23-2012, 07:41 AM
roo roo is offline
Rep:39
Good info Black Ram, had no idea using 2nd prime for an upshift would hurt the tranny. And headers will be first on my list when shorties are available.
Old 03-23-2012, 10:09 AM
Rep:554
BBK and JBA both make 4G Hemi shorties, you can even get them in silver ceramic coated.
I got my JBA's yesterday, $555
pretty sure they would fit a 12' Hemi too.
BBK Shorties go for $399 (coated)
Old 03-23-2012, 03:03 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 Dodge Ram SRT10 RC 6spd
Trim Level: SRT10 RC
Color: Brilliant black
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
Do the Express's have limited slip or does it have to be ordered, and what are the gear ratio choices? thanks, been looking at one recently.
Traded in[SIGPIC]2004 SRT10 RC in black, with 500+HP, B&G Stage2 PCM, K&N drop in, JMB Catless mids, JTSVP Gen1 shifter, all synthetic fluids, lots of underhood billet with a Snakeskin radiator cover from JTSHydro, LED tails, BedRug, colormatched tonneau!!!!!!!! Upgraded!!!!!!!!
Old 03-23-2012, 03:30 PM
Rep:554
3.55's are standard, open diff
+$325 to add an LSD to 3.55's
to upgrade to 3.92's(open) its $50, +$325 for LSD = $375
Old 03-23-2012, 05:13 PM
snrusnak's Avatar
Rep:1385
^cheap if you do it up front! $$$ if you do it after...
Sean
