Old 03-11-2012, 06:35 PM
djbaselle djbaselle is offline
Vehicle: 2012 DODGE RAM
Color: BLACK
djbaselle is on a distinguished road
Default Radio and amps wont turn on
I WAS DOING AND INSTALL and when i was testing it and I'm guessing something shorted out and killed all my power. i checked the fuse and its good..
Someone help ASAP please
Old 03-11-2012, 07:09 PM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
You posted the same question twice... Did you check the fuse in the head unit and the one in the fuse box? I don't get how you shorted it in the first place. Did you use a canbus adapter? More info needed....
Old 03-12-2012, 06:20 AM
Color: BLACK
I was moving the amp around and tucking the away it shorted out. I checked both those the fuses.. I'm so lost
Old 03-12-2012, 08:46 PM
rtkman's Avatar
Rep:167
Ok so you shorted out the big 4 guage power wire going to your amp right? And the head unit has no power? Or just the amp? There should be a fuse in the amp itself as well as a large one between your amp and the battery. Test for power on both sides of the big fuse using a test light.
Old 03-13-2012, 12:27 AM
Color: BLACK
the yellow wire has power,,, its the red acc wire that doesn't have a signal... which is stopping my radio from turning on...
Old 03-22-2012, 10:13 PM
NightRazor's Avatar
NightRazor NightRazor is offline
Vehicle: 2012 Dodge Ram
Trim Level: 1500 SXT Quadcab 4x4
Rep:16
NightRazor is on a distinguished road
you said you checked the fuse. but there are more than one, each piece of gear has their own (last ditch effort)
there should be a fuse inside the cabin noted as stereo or something to that effect.
and last but NOT least, there is one in the engine bay as well, should be names something like acc or accessory
