Inexpensive Remote Start using OEM key fobs - Page 10 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 04-21-2012, 11:12 PM
kdramman kdramman is offline
Vehicle: 2009 Ram Crew Cab 4x4
Rep:78
kdramman will become famous soon enough
Originally Posted by thines View Post
hey guys, how did you hook up the Hood pin and Neutral Safety Switch?
I ran a single wire under the hood for the hood pin, but haven't hooked it up yet.
For the safety switch, I just used a small toggle switch hooked between wire 6 of the black 10 pin harness and ground. Mounted it at the bottom of the kick panel.
Old 04-21-2012, 11:33 PM
voodoochi1d's Avatar
voodoochi1d voodoochi1d is offline
Vehicle: 2009 Dodge ram 1500 slt
Color: silver
voodoochi1d is on a distinguished road
dumb question, but what are these needed for? Hood pin and saftey switch
Old 04-21-2012, 11:44 PM
Rep:78
The hood pin keeps the Remote Start from engaging if the hood is open.
The safety switch is simply an on/off switch for the remote start, like when you're changing the oil or working on it.
Old 04-21-2012, 11:53 PM
Color: silver
good to know, Thanks... will need to install both.
Can someone please giive more detailed directions how to install these two items?
Old 04-22-2012, 11:22 AM
thines thines is offline
Vehicle: 2012 Dodge Ram
thines is on a distinguished road
Thanks Kyle. One last thing, UPS can't find my T-harness so I'll try splicing. On the instruction, connect ignition switch pin# 3 to DBALL 14pin pin # 8 & 9 and there's a scissor diagram. What does the scissor mean? cut the wires?
Old 04-22-2012, 08:59 PM
Rep:78
Yep, that's correct.
Old 04-22-2012, 09:40 PM
Ok. I'm leaving 8pin on 14pin harness out and just connect pin9 to ignition pin3.
Old 04-22-2012, 09:50 PM
Rep:78
Just to clarify, it should be hooked up so that the ignition signal comes from the module connector, into pin 9, and then out of pin 8 into the truck.
Both pin 8 and pin 9 hooked to the same wire, but one on the "key switch" side, and one on the "truck" side.
Both 8 and 9 are required to make it work.
It has to be connected so that it can "fake" the ignition signal going to the truck.
Sorry for the wordiness, just wanted to make sure that we're on the same page.
Old 04-22-2012, 09:52 PM
Rep:78
The hood pin switch is a plunger style switch that opens a circuit when the plunger is compressed (hood closed), and closes a circuit when the plunger is extended (hood open).
http://www.parts-express.com/pe/show...number=060-245
The Hood pin is mounted in a hole under the hood along the rim of the engine bay. It has to be in a spot where the edge of the hood will cause the plunger of the hood pin to collapse when the hood is shut. The hood pin has to be in contact with metal to complete the circuit when the hood is open. On the end of the pin you can insert a bullet or female wire connector.
This wire can then be connected to pin 6 of the black 10 pin harness of the DB-ALL, which is an input wire. When this input wire is connected to ground (through the hood pin switch or toggle switch), this will cause the DB-ALL to not initiate a start sequence.
The "neutral safety switch" is a toggle switch that can be mounted anywhere you want and connected to ground on one side, and the same wire as the hood pin switch on the other. Turning the switch on is effectively sending wire 6 of the black 10 pin harness to ground. You can think of this as an on/off type switch for the RS.
As a side note: If you ever read of a neutral safety switch in a car, it typically means a switch that is connected in a way to show the car is actually in neutral, and can safely be started. What they are calling a "neutral safety switch" would really be a "safety switch" instead. Just a little fyi in case anyone ever gets confused.
Here is a link to the install manual of the DB-ALL. It shows where the wire is located that needs to be hooked up.
http://www.xpresskit.com/DocumentDow...irmwareid=2573
Old 04-22-2012, 10:22 PM
Thanks man. I see it now. I'm just waiting on my flasher now. I'll take some pictures for others not going for the t-harness.
