Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 05-09-2012, 04:14 PM
roaddog665's Avatar
roaddog665 roaddog665 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Quad Cab SLT 4x4
roaddog665 is on a distinguished road
Originally Posted by kdramman View Post
I'm pretty sure it is 10 minutes, maybe 15. I forgot and left mine running the other day and it shut itself off.
Outstanding, thanks for the reply. And thanks for the info. I found your install video on YouTube and thats how I found this forum. Guess I owe you twice!
Jon
2009 1500 Quad Cab 4x4 SLT 4.7L
Old 05-09-2012, 06:06 PM
DILLIGAF's Avatar
DILLIGAF DILLIGAF is offline
Vehicle: 2012 DODGE RAM
Color: Charcoal Grey
DILLIGAF is on a distinguished road
WOW thanks for this info....
Old 05-25-2012, 08:22 PM
Ram11's Avatar
Ram11 Ram11 is offline
Now 2012
Vehicle: 2012 Dodge Ram 1500
Color: Deep Red Pearl
Rep:146
Ram11 will become famous soon enoughRam11 will become famous soon enough
I did mine today,,, The DB-All Module came flashed, so that was ok,, I also bought the T-harness,,, hooked it up and nothing,,
I tried over and over until I gave up and called tec support,,
What they said I needed to do was, take the small wires that have the black plug on the end and plug it into module,,turn the ignition on,,,then take the green wire from that and touch ground, and then and only then did it work,,,, Buttoned it back up and i'm good to go,,,,
Total cost,,, 92.00,, total time for install 15 minutes,, 45 minutes waiting for the tech,, 3 minute of actual talk time
Good To Go,,,,,
Factory Fender Flare's... Smoked Rain Guard's... 8,000 Hid'... Zeta Body Side Molding... Painted Pinstripe... Dodge S/S Door Sills... S10 Bed Slide... Ghost Flames... Mopar Tonneau Cover... Mopar High Performance Exhaust... K and N Cold Air Intake...Bilstein 4600 Front Shocks.....Thunder Form enclosure Loaded with 2 10 Kenwood Subs,,
Old 06-23-2012, 06:34 PM
s9779's Avatar
s9779 s9779 is offline
Vehicle: 2011 ram
Trim Level: sport
Color: gray
s9779 is on a distinguished road
worked great took less then 5 min to install i wish everything was this simple. got everything on ebay for less the 70 bucks
2011 RAM 1500 crew cab
Old 07-19-2012, 10:18 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
This aint workin!!!!!!!!!!!
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 07-19-2012, 10:46 PM
300MAG 300MAG is offline
Vehicle: 2011 Ram 1500
Color: Deep Cherry Red
Rep:23
300MAG is on a distinguished road
Check post #113, perhaps you have the,same issue. Who programmed your module, perhaps it was done incorrectly.
Old 07-22-2012, 05:10 PM
smclaren76 smclaren76 is offline
Vehicle: 2008 dodge ram
smclaren76 is on a distinguished road
i recieved my kit with the t harness have it all hooked up when i hit the lock 3 times everything inside comes on like the heater radio but it does not start. the green light flashes and then the horn honks and everything shuts back off. any ideas.
Old 07-22-2012, 07:23 PM
Rep:23
Looks like it is a issue with programming, check this thread....post#25 & 29. hopefully it solves your problem.
http://www.ramforumz.com/showthread.php?t=107176
Old 07-23-2012, 08:48 AM
Arrow
It is responding to the keyfob everything turns on just won't crank over. Would this still be a programming issue?
Old 07-23-2012, 06:09 PM
are you guys hooking up any wires to the door pin in the kick panel?
