Inexpensive Remote Start using OEM key fobs - Page 13 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 07-24-2012, 09:11 PM
31Always 31Always is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Crew Cab
31Always is on a distinguished road
great write up, I just posted a thread asking wether anyone has had any luck with the Xpresskit DB-all. Obviously I didn't look hard enough for this thread. A couple questions. . . does this void the factory warranty? and are the hood pin and neutral safety switch necessary to install?
Thanks
Old 07-25-2012, 09:54 AM
robby5323 robby5323 is offline
Vehicle: 2011 Ram Express
robby5323 is on a distinguished road
Thanks
I am not using a hood pin or neutral safety switch. Mine works fine and I use it all the time. As far as voiding the factory warranty... I wouldn't worry about it coming into play in a warranty void situation.
Old 07-25-2012, 07:12 PM
phillymac23 phillymac23 is offline
phillymac23 is on a distinguished road
Well, read this post last week and ordered the DBALL, T harness, and Xkloader. I received all items on Monday. I flashed the DBALL, then plugged in the harness and programmed the DBALL. Hit the lock button 3x times and the truck started, btw it's a 2012 Ram 1500 Express. Hit the lock button 3x times and it shut off. Then I tried to start the truck with the key and no go, it would not started. Unplugged the T harness and the truck started fine. I called Xpresskit and they said it was a bad T harness. I finally found a somewhat local shop that had the harness and picked it up tonight. Plugged it in and everything is working fine. I do have one question for everyone that has done this mod, when the truck is running are your parking lights on? Mine are not and I thought the parking lights were handled through the DBALL on the Dodge's. I have a Python 574 coming and Xpresskits said that with D2D the only connections needed are 3 12v wires, pink ignition wire, ground, siren, and hood pin. I guess we will see when it gets here. I hope that's it, I'm not big on splicing wires.
Old 07-26-2012, 01:24 PM
300MAG 300MAG is offline
Vehicle: 2011 Ram 1500
Color: Deep Cherry Red
Rep:23
300MAG is on a distinguished road
Geez, they need to do a better job bulding the t-harness....this is the 3rd t-harness I read about being defective.
Old 08-03-2012, 09:33 AM
yodahog's Avatar
yodahog yodahog is offline
Vehicle: 2011 Dodge Ram
Trim Level: 4x4 CrewCab Sport
Rep:21
yodahog is on a distinguished road
Originally Posted by thines View Post
Man... That sucks... Back to eBay then. Thanks Robby.
Did you ever get yours working? Mine arrived flashed with the setting at DEI instead of RFTD (seller sent me a similar sheet as yours) so was wondering if that is indeed the issue.
My remote start with the key fob is not working.
Old 08-04-2012, 08:46 PM
thines thines is offline
thines is on a distinguished road
Yeah. After reflashing to RFTD it worked fine.
Old 08-05-2012, 03:05 PM
My park lights don't come on
Old 08-08-2012, 09:07 AM
yodahog's Avatar
Rep:21
Thanks - bought the xkloader2 and reflashed to RFTD and it is working.
Old 08-11-2012, 05:16 PM
rinnels69's Avatar
rinnels69 rinnels69 is offline
Vehicle: 2013 Dodge Ram Sport
Rep:19
rinnels69 is on a distinguished road
I too, just dropped the hammer on this must have mod. Will update once installed and tested.
MODS: G2, Timbren SES, ITBC, de-badged....to-do--HB horns and nerf bars
Old 08-12-2012, 02:36 AM
scott917 scott917 is offline
Vehicle: 2012 Dodge Ram 1500 Express
scott917 is on a distinguished road
to the OP, thanks a ton for doing this write up. i am off to search for the parts and can not wait to get this done! you are too awesome!
will keep posted on this as i get the ball rolling on it.
S
