Inexpensive Remote Start using OEM key fobs - Page 16 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 10-08-2012, 12:42 PM
JCummings's Avatar
JCummings JCummings is offline
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
JCummings is on a distinguished road
Ordered my parts!!!! Can't wait.
Mods: Lowered and Blown.
Old 10-12-2012, 02:38 PM
Rescue1 Rescue1 is offline
Vehicle: 2017 RAM 2500
Color: Murdered out
Rep:64
Rescue1 will become famous soon enough
Originally Posted by Exxzaust View Post
Can someone PM me that has done this on their 3rd gen or send me in the right direction please
This cannot be done this way on the early third Gen trucks, as you will need to install a conventional remote start with transponder bypass if you have the gray key(The black key isn't required to have that). Not sure about the 3.5 Gen trucks though, as they started to get the newer CAN Bus systems from the factory...
Old 10-12-2012, 02:40 PM
Color: Murdered out
Rep:64
I did mine yesterday, took be about 30 minutes to do as I was cheap and didn't buy the T Harness. As for the hood switch, I used a plastic enclosed mercury tilt switch and stuck it to the underside of the hood. Works well....
Old 10-13-2012, 11:00 AM
JCummings's Avatar
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
received my parts, went to instal and it is not recognizing my key FOB looks like they did not flash it correctly. Should have purchased the xloader2 to do it myself. Why is it that people can not do things correctly the first time? I am extremely frustrated right now.
Old 10-13-2012, 10:57 PM
purodude's Avatar
purodude purodude is offline
Vehicle: 2012 ram 1500 crew cab
Trim Level: sport
Color: bright white
Rep:16
purodude is on a distinguished road
Same shit here. Got it off ebay seller wants me to send back at my expense
Old 10-14-2012, 11:21 PM
Waldo Waldo is offline
Vehicle: 2012 Dodge Ram
Color: Mineral
Waldo is on a distinguished road
Hi guys, have mine on order and should be here by Wed. Can both the key fobs be programed? As far as the hood pin can I just tie into my under hood light? Great find and awsome forum!!
Old 10-14-2012, 11:25 PM
Color: Mineral
How many key fobs can be programed?
Old 10-15-2012, 02:21 AM
Color: Murdered out
Rep:64
The unit doesn't care how many FOBS are programmed. Basically all the Key FOBs have the same code, the DB unit just needs that code to send the address to the FCM/PCM on the CAN C Bus for the start sequence....
Old 10-15-2012, 12:16 PM
Color: Mineral
Thank you Sir! The wife wants her (really mine to) remote to start up the truck.
Old 10-15-2012, 12:21 PM
Color: Mineral
Originally Posted by readster1 View Post
This looks like it might be a good upgrade, but what I was wondering is on the factory key fob there is what seems like extra buttons so when you first activate the key instead of pressing the lock button could another button be utilized instead???My other question is:when the lock button is pressed 3 times does the trucks horn honk or does it know you are trying to start the truck and bypasses this feature,and does it lock the doors and honk the horn when you just press it once??Also is it possible to set up the dball to act like the factory remote start where the heated seat and steering wheel will come on or the A/C when it is warm?? Just curious hope some will chime in that has knowledge on this thanks in advance
Im sure you guys already know this, but I found this today at work about the horn chirp:
Sound Horn With Remote Key Lock
This feature will cause the horn to chirp when the doors
are locked with the RKE transmitter. This feature can be
turned on or turned off. To change the current setting,
proceed as follows:
• For vehicles equipped with the EVIC, refer to “Electronic
Vehicle Information Center (EVIC)/Customer-
Programmable Features (System Setup)” in “Understanding
Your Instrument Panel” for further
information.
• For vehicles not equipped with the EVIC, perform the
following procedure:
1. Press the LOCK button on a programmed RKE transmitter
for at least four seconds, but no longer than ten
seconds. Then, press the PANIC button while still holding
the LOCK button.
2. Release both buttons at the same time.
3. Test the feature while outside of the vehicle by pressing
the LOCK button on the RKE transmitter with the
ignition switch in the OFF position and the key removed.
4. Repeat these steps if you want to return this feature to
its previous setting.
NOTE: Pressing the LOCK button on the RKE transmitter
while you are in the vehicle will activate the Vehicle
Security Alarm System. Opening a door with the Vehicle
Security Alarm System activated will cause the alarm to
sound. Press the UNLOCK button to deactivate the
Vehicle Security Alarm System.
Using The Panic Alarm
To turn the Panic Alarm feature ON or OFF, press and
hold the PANIC button on the RKE transmitter for at
least one second and release. When the Panic Alarm is on,
the headlights will turn on, the park lights will flash, the
horn will pulse on and off, and the interior lights will
turn on.
Any one know if we can use one of the other buttons on the fob instead of the lock one?
