Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 10-16-2012, 12:44 AM
mr gummy mr gummy is offline
Vehicle: 12 Dodge Ram 1500 QC
mr gummy is on a distinguished road
I have 2012 express and installed all the items and nada.......I checked the flash sequence and I'm getting green red green.....is that right?
Old 10-17-2012, 11:57 AM
Rescue1 Rescue1 is offline
Vehicle: 2011 Dodge Ram
Rep:64
Rescue1 will become famous soon enough
When you put the key(FOB) in the first time did you hit the learn button on the DB unit? I had to do that when it went in my Jeep....
Old 10-17-2012, 08:01 PM
Waldo Waldo is offline
Vehicle: 2012 Dodge Ram
Color: Mineral
Waldo is on a distinguished road
Did mine today and worked like a charm! Both key fobs work great, Thx gents!!
Old 10-18-2012, 11:47 AM
haney's Avatar
haney haney is offline
Color: Grey
Rep:15
haney is on a distinguished road
Default Remote start
does anyone know how many feet this will work from RANGE?
Old 10-22-2012, 05:24 AM
aepowell's Avatar
aepowell aepowell is offline
Vehicle: 2013 Dodge Ram SLT LONESTAR
Trim Level: 1500 SLT LONESTAR QC
Rep:99
aepowell will become famous soon enough
Going to do mine this morning. I hope it works the first time around. I bought it off the same seller as the person that started this post. They said they would have it programed for a 2010 Ram. I hope so.
Aepowell Sherman,TX.
Old 10-22-2012, 11:07 AM
aepowell's Avatar
Rep:99
Originally Posted by kdramman View Post
Can't send PM's yet.
If you plug in the the harness to the DB-ALL and the green light comes on and then goes off, then the unit is programmed to your truck.
The DB-ALL doesn't flash the LED for anything except the remote start. Meaning that when you lock or unlock the doors, the LED doesn't flash. This is what troubled me when I first put mine in.
It's a little sensitive to the 3 distinct locks within 3 seconds. If the parking lights don't flash, then the DB-ALL doesn't see the signal.
I think your problem is that the unit is not set to RF-OUT. You can check by going into the programming mode of the DB-ALL.
This is in the DB-ALL manual on page 22, but I'll try and give you the steps.
1) Turn Key to on and then remove key.
2) Hold down the black button on the DB-ALL.
3) After 3 seconds the LED will turn orange then go off.
4) Let go of the button.
It will blink green to tell you which feature it is on, and then red to tell if it is activated or not.
RF-Out is feature 1- 1 blink green. On is 2 blinks red, off is 1 blink red.
You'll want it to blink Green, Red, Red......
To change the options you'll have to use the black 10 pin harness.
A pulse of the LOCK wire (green) to ground will change the option.
Let me know if that helps or not.
I cant get mine to work. When I hit the unlock 3 times the parking lights blink but that is all it does. When i run the above test it goes green red ,green red green red I tried to start it manually by grounding the blue/white wire on the black 10 pin then touched the pink and violet to 12 volt hot and it didn't start the truck. When I touch the green or blue to ground it will lock and unlock the truck. I got my unit from the same dealer you bought yours from and he was supposed to program it for my ram. Wher do I go from here?
thanks,
aepowell
Old 10-24-2012, 08:51 PM
whoa black betty's Avatar
whoa black betty whoa black betty is offline
Vehicle: 2015 Ram Express
Trim Level: Yea...it's got one!
Color: BLACK
whoa black betty is on a distinguished road
Any body with 2012 Ram that ordered off Ebay and got correctly programmed the first time remember who the seller was? Thanks
Old 10-25-2012, 12:07 AM
aepowell's Avatar
Rep:99
I.m having the same problem. It should be Green Red Red.
Old 10-26-2012, 07:59 PM
Color: Mineral
The seller I bought mine from a couple weeks ago is
<H1 id=itemTitle class=it-ttl itemprop="name">Directed Xpresskit Combo DBALL & CHTHD1 T-Harness w/ Firmware for YOUR vehicle</H1>
doug43235
I just sent an e-mail with my order and told him it was for a 2012 Ram with 3X key fob start. He flashed it for free and it worked great first time around.
Old 10-27-2012, 08:48 AM
JCummings's Avatar
JCummings JCummings is offline
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
JCummings is on a distinguished road
OK, so after I received my "flashed" DBALL and it did not work (due to incorrect D2D settings) I wrote the seller of the DBALL unit. I informed him that I was upset that I had to purchase the XLoader2 to fix it myself and he fully refunded me for the price of the XLoader. In the end, every thing works fine and I now own the XLoader. I was extremely upset at first but the seller was very understanding and worked well with me. I hope that anyone who ordered the incorrect stuff gets the same customer service.
Mods: Lowered and Blown.
