Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 10-27-2012, 05:14 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Sounds like this is the mod of the year!!
Love mine. Except one thing. Every so often when I hit it the starter just engages but doesn't spin over. Does it 3 times then horn chirps for a fail. Then I try it again and bam. Fires up!
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 11-12-2012, 06:30 PM
SwampDonkey2012 SwampDonkey2012 is offline
Vehicle: 2011 Dodge RAM Sport Crew
Trim Level: Sport w/ Sunroof
Color: Pearl Black
Rep:13
SwampDonkey2012 is on a distinguished road
Just ordered a DB-ALL and a CHTHD1 for my 2011 Sport CC. I haven't seen much from 2011 owners on this thread. I hope I purchased the correct pieces.
I also added notes for the seller to please include the correct flash, and to please please set the D2D to (RFTD) before shipping so I wont have to buy the programmer.
Anything I'm missing? I hope to get this unit, plug it in, turn my key, press lock, and hopefully start it right up!! Please let me know if it looks like I'm missing anything for the 2011.
Old 11-13-2012, 07:36 PM
miamidad miamidad is offline
Vehicle: 2012 Ram Express Crew Cab
Trim Level: LSD, TBCG
Rep:54
miamidad will become famous soon enough
Question
Questions for those who have already installed it.
How long will the car stay on, if you don't go and really turn the ignition? (my other dodge has factory remote start, and it will stay on for about 15 minutes if i dont go)
How does it handle the A/C? Do you have to leave the a/c on the setting you want or does it default to a specific fan speed and temperature?
I have a 2012 express cc.
Thanks
Old 11-14-2012, 08:16 PM
Waldo Waldo is offline
Vehicle: 2012 Dodge Ram
Color: Mineral
Waldo is on a distinguished road
Thanks
On mine it stays running for 10 min, then the horn chirps and it shuts off. Mine has the manual a/c buttons so I leave it set to where i want (or the heat). I think the trucks that have the digital panel has a factory sensor that senses how much heat or a/c is needed, could be wrong on that one though.
Old 11-15-2012, 12:23 AM
olds442111 olds442111 is offline
Vehicle: 2011 Big Horn Ram
olds442111 is on a distinguished road
Just ordered everything for my 2011, preflashed and should be plug n play. We shall see.
Old 11-15-2012, 11:19 AM
aepowell's Avatar
aepowell aepowell is offline
Vehicle: 2013 Dodge Ram SLT LONESTAR
Trim Level: 1500 SLT LONESTAR QC
Rep:99
aepowell will become famous soon enough
Originally Posted by aepowell View Post
I cant get mine to work. When I hit the unlock 3 times the parking lights blink but that is all it does. When i run the above test it goes green red ,green red green red I tried to start it manually by grounding the blue/white wire on the black 10 pin then touched the pink and violet to 12 volt hot and it didn't start the truck. When I touch the green or blue to ground it will lock and unlock the truck. I got my unit from the same dealer you bought yours from and he was supposed to program it for my ram. Wher do I go from here?
thanks,
aepowell
update
I just received my replacement unit this morning and it worked the first time.
Aepowell Sherman,TX.
Old 11-15-2012, 11:23 AM
Outlaw's Avatar
Color: Bright white
Rep:435
You're supposed to hit the lock not unlock button.
[/CENTER]
Old 11-15-2012, 08:50 PM
aepowell's Avatar
Rep:99
I know that ,I just wrote it wrong. Thanks
Old 11-19-2012, 06:42 PM
Color: Pearl Black
Rep:13
Update on the Remote start install. Received my DB-ALL Module from hot.electronic on Ebay.
http://www.ebay.com/itm/130800506206...84.m1497.l2649
Asked him to program it accordingly. Received an email within an hour acknowledging my request. Had to wait over the weekend for the wiring harness CHTHD1. Went home on my lunch break today and the harness was there. Took a phillips head out there and my tablet. Pulled up this thread, watched the video one last time just to be sure.
Dropped the dash, disconnected the ignition wire, plugged it into the harness, plugged the truck into the other end of the harness, connected the harness to the DB-ALL. Followed the instructions EXACTLY in the video on pg 1 of this thread. Got the solid green light. Pressed lock three times! Presto! Truck started. I'm so stoked at the ease of this mod. If you haven't done yours yet, don't hesitate. My only advice would be to use the seller I mentioned above, and make sure to email him your model vehicle. Also, ask him to set the RF output to the correct setting. I did this and it arrived in perfect condition and worked first time. Literally took me more time to go to my tool box, get a zip tie, and tie the DB-ALL up inside the dash. Also I really like the idea that the only tool I needed was a phillips screwdriver. Can't beat that. Anyway, just wanted to update you guys who are a little hesitant like I was. Pull the trigger!!! you will be glad you did. I am. Just in time for the cold weather here in TX!
With the auto climate control in my truck always set to 71 degrees, this will be a handy feature this winter and next summer! Hope this helps some others out there. This forum is priceless when it comes to these things!
Old 11-19-2012, 10:32 PM
purodude's Avatar
purodude purodude is offline
Vehicle: 2012 ram 1500 crew cab
Trim Level: sport
Color: bright white
Rep:16
purodude is on a distinguished road
Boooo. Ur link to the seller doesn't work.
