Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 03-12-2012, 11:26 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
One last thing; do you by any chance have a link to the supplier? You mentioned the seller on ebay programmed yours; it would be nice to order from that seller if possible. They obviously got it right. Thanks
Old 03-12-2012, 11:51 PM
kdramman kdramman is offline
Vehicle: 2009 Ram Crew Cab 4x4
Rep:78
kdramman will become famous soon enough
Thanks guys, I appreciate that.
I probably should have left out that part about the RF output, as most people would never need to mess with it, but I tend to get caught up in the details of things.
The RF Output Type is a feature in the Feature and Option List of the DB-ALL module. This can be turned on or off depending on what you have plugged up to the DB-ALL. If you are using the DB-ALL as a stand-alone unit (aka: RSR-Remote Start Ready), then the RF Output Type has to be set to on. If you are using a separate alarm/rs unit (ex. Viper 5901 ect.), then this can be set to off.
When you flash the DB-ALL with the XKLoader2, it automatically sets this to ON for you. So if you ordered it already flashed, you wouldn't have to worry about it.
One day when I was still trying to get everything to work, I thought I would reset the module to see what would happen. I did this not knowing it would reset the RF Output option. So I had to manually pulse the door lock wire to negative while in programming mode to change the options.
Hope I was able to explain that concisely and clearly.
Here is a link to ebay where I purchased the DB-ALL.
http://www.ebay.com/itm/XPRESSKIT-DB...item19cdc38210
I'll also include the link to the DB-ALL manual for the Remote Start Ready stand-alone installation.
http://www.xpresskit.com/DocumentDow...irmwareid=2573
--Kyle
Old 03-13-2012, 09:55 AM
krazybone krazybone is offline
Vehicle: 2010 ram 1500 4x4
Trim Level: Laramie/Sport/SLT
Color: Metallic Silver
krazybone is on a distinguished road
Would i be able to complete this the same way on an 05?
k
Old 03-13-2012, 04:40 PM
Rep:78
No, it is for 06 and up.
--Kyle
Old 03-13-2012, 05:26 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Excellent writeup, rep points coming your way.
Old 03-14-2012, 08:54 PM
Huka42's Avatar
Huka42 Huka42 is offline
Vehicle: 2009 Dodge Ram 1500
Huka42 is on a distinguished road
Where did you end up installing the DB-ALL unit? Does it go under steering column? Thanks!!
Old 03-14-2012, 09:54 PM
Rep:78
Yeah that's where I put it. There might be a place over to the right to hide it, but I didn't go to that much trouble. The T-Harness should be long enough to tuck it away somewhere.
--Kyle
Old 03-14-2012, 11:15 PM
robby5323 robby5323 is offline
Vehicle: 2011 Ram Express
robby5323 is on a distinguished road
I just ordered this unit and a T harness. I have been looking for a cheaper alternative to the factory unit. Many thanks!
Old 03-14-2012, 11:21 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Wish I had known about this before I bit the bullet and bought the OEM remote start. Great write up and nice find!
Chrome... in moderation.
Old 03-15-2012, 07:51 PM
ramSpoons ramSpoons is offline
ramSpoons is on a distinguished road
oh my god this is awesome. i wanted to get remote start for the longest time but didnt want to pay the hundreds of dollars it takes to install it at the dealer.
