Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 02-10-2013, 03:49 AM
smiley87 smiley87 is offline
Vehicle: 2013 ram 1500
Trim Level: express
Color: true blue
smiley87 is on a distinguished road
Am I reading the website correctly where it states this does not work on the 2013 1500?
Old 02-13-2013, 06:44 PM
kevmic28's Avatar
kevmic28 kevmic28 is offline
Vehicle: 2010 Dodge ram quad cab
Trim Level: TRX
Color: Inferno Red Pearl
kevmic28 is on a distinguished road
Got mine in the mail today.Took about 2 minutes to install and works perfectly.
Old 02-15-2013, 07:53 PM
kmease kmease is offline
Vehicle: 2012 Dodge Ram Quad Cab
Trim Level: Tradesman
kmease is on a distinguished road
Could someone take some screenshots of programming the dball again. The settings have changed and my unit is being a B!%@h.
Old 02-16-2013, 12:27 PM
I spoke to the tech support and they said the only way to change the "RF OUT" is manually for now.... so much for buying the xkloader....
Old 02-16-2013, 01:22 PM
300MAG 300MAG is offline
Vehicle: 2011 Ram 1500
Color: Deep Cherry Red
Rep:23
300MAG is on a distinguished road
Stupid question, but how do you change it manually if not using the xloader.
Old 02-16-2013, 10:04 PM
Using the black 10 pin connector. Maybe someone else can elaborate on how to do it specifically.
Old 02-17-2013, 03:42 PM
I have a fix people!!! After being frustrated as hell I read the manual and found the fix. You don't need the xkloader nor the 10 connector. If your RF out is off, but the dball is programmed to your vehicle, do this.
Connect the dball to your vehicle
Turn the key to on, then turn it off and pull out key.
Hold programming button on dball until orange light shows, then let go.
Then dball will the flash green. When you see the green light, click the unlock button on your key fob.
Then dball should then be flashing, green red red, which is the correct programming.
Hold the programming button again until orange. Bam!!!
Lock three times and presto!
Hope this helps guys.
Old 02-17-2013, 06:43 PM
Mojack's Avatar
Mojack Mojack is offline
Vehicle: 2012 Ram 1500 ST
Rep:65
Mojack will become famous soon enough
Glad you figured it out! I didn't get a manual with mine, but this sounds like the fix that the seller had me go through over the phone. This means it WASN'T me goofing up the install, it was HIM not setting the RF out correctly like I asked when I bought it.
2012 Ram 1500, 1986 RamCharger,
1972 Duster 340, 1965 Valiant 340
Old 02-17-2013, 08:23 PM
I didn't have my manual or the 10 pin connector so I just looked up a manual on the internet. I guess they have recently changed the way you program the dball. There's no longer an option for rftd just from a features list while flashing it. So it might not have been your guys fault. Although blaming you was :P.
Old 02-17-2013, 09:45 PM
Mojack's Avatar
Rep:65
OK, he didn't blame me, but there were no instructions what so ever with the DBall, I was just trying to install it according to instructions in this thread. When I emailed him he was good to call me and talk me through it. It works good, so I'm happy.
BTW it works good, but when I put the key in the ignition and turn to run, I get a message of "low tire" once on the display, but no warning light. Anybody else get this?
