Inexpensive Remote Start using OEM key fobs - Page 5 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 03-30-2012, 12:30 AM
kdramman kdramman is offline
Vehicle: 2009 Ram Crew Cab 4x4
Rep:78
kdramman will become famous soon enough
Originally Posted by robby5323 View Post
Thanks for the help! I went and messed with it some more. If I hit the lock 3 times no lights on the DB ALL, do have parking lights each time. I check the RF Out sequence and it was the green, red, red. I'm baffled on this one. I wonder if there is something that is keeping the DB ALL from sending the start signal? Some kind of theft prevention or something in the computer encryption?
I am whipped at this point.
Sorry to hear you're having so much trouble with it. I felt like this when I was first getting mine hooked up. I was about ready to throw it.
I have an idea to see if it is communicating with your truck's mux system.
Use the black 10 pin harness to see if the door locks work, and then manually remote start it by using the other wires in the black 10 pin harness.
You can use the GWR, Ignition, and Starter wires to start the truck.
This would let you know if the DB-ALL is able to send the right signals.
I did this before because I thought mine wasn't working either.
Old 03-30-2012, 11:02 AM
robby5323 robby5323 is offline
Vehicle: 2011 Ram Express
robby5323 is on a distinguished road
Thanks for the ideas. I will try and figure which wires are which on the black harness and how/where to connect them to give this a go.
Old 03-30-2012, 10:30 PM
Rep:78
Here is a link to the manual that shows all the harnesses.
http://www.xpresskit.com/DocumentDow...irmwareid=2573
Old 03-31-2012, 11:16 AM
It looks like I can't find a way to try the black harness wire connections without cutting and splicing into the factory wiring? I can't bring myself to do it on a brand new truck with only 2000 miles on it with the hope I might get lucky...
Old 03-31-2012, 10:10 PM
CaddyRam's Avatar
CaddyRam CaddyRam is offline
Vehicle: 2010 Ram
Trim Level: Slt Big Horn CC
Rep:12
CaddyRam is on a distinguished road
Great post. Thanks for the write up.
Mufflex18,limo tint,DNX 6960w/rearview camera, sirrius satellite,DVD,Nav,radar detector/video camera mount, Damplifier.Ez down tailgate assist,bed extender, LineX,relocated rearwindow switch,custom twin filter air intake,custom front/rear center consoles w10'' Kappa and LED lighting.
Old 04-01-2012, 12:53 PM
Rep:78
You don't have to cut or splice into anything. The DB-ALL handles all the functions through the CAN bus system. The T-Harness takes care of all that.
To start the truck with the 10 pin black harness, you simply put the GWR wire (#10 Blue/White) to ground, then 12v to the ignition wire (#9 Pink), and then 12v to the start wire(#8 violet) long enough to start the truck. This will "remotely" start the truck through the DB-ALL.
To get the DB-ALL to lock the doors, you pulse the #1 Green wire to ground. Just touching the wire to ground, will cause the DB-ALL LED to flash and the doors will lock. The same thing can be done with the unlock.
Old 04-02-2012, 05:14 AM
thines thines is offline
Vehicle: 2012 Dodge Ram
thines is on a distinguished road
Originally Posted by teenRam View Post
Wow. How much does the dealership charge for something like this?
Here's what my dealer quoted.
Old 04-05-2012, 09:54 PM
osow0029 osow0029 is offline
Vehicle: 2012 Ram 1500
osow0029 is on a distinguished road
I tried installing on my 2012 Ram 1500 and got the same result. i push the lock button three times and nothing happens. Any ideas?
Old 04-08-2012, 12:59 AM
Rep:78
Not sure whats up with the 2012's. Maybe the Xpresskit needs an updated firmware to work with the newest trucks. Ill dive into it and see what I can figure out.
Old 04-08-2012, 11:06 PM
Rep:78
Do you have a manual Transmission?
