Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 04-09-2012, 08:51 AM
robby5323 robby5323 is offline
Vehicle: 2011 Ram Express
robby5323 is on a distinguished road
Originally Posted by osow0029 View Post
I tried installing on my 2012 Ram 1500 and got the same result. i push the lock button three times and nothing happens. Any ideas?
I'm thinking that there must be something in the encryption keeping the unit from operating properly. I went through trouble-shooting with the manufacturer via email and no resolution....
Old 04-09-2012, 01:36 PM
osow0029 osow0029 is offline
Vehicle: 2012 Ram 1500
osow0029 is on a distinguished road
Thanks for the update. I have also been working with a rep and will keep you posted if I get it to work.
Old 04-09-2012, 02:45 PM
Thanks, Appreciate it!
Old 04-10-2012, 11:34 PM
The Expresskit rep assures me it has been tested and will work with the 2012 Rams. The only thing he can figure out is a bad wire harness but I dont think that is the problem.
Old 04-11-2012, 08:51 AM
Yep, same thing I got. Who knows...?
Old 04-11-2012, 05:30 PM
thines thines is offline
Vehicle: 2012 Dodge Ram
thines is on a distinguished road
Hope you guys with 2012 models could get it to work coz I have mine on its way. Wish us luck.
Old 04-11-2012, 06:06 PM
Originally Posted by kdramman View Post
You don't have to cut or splice into anything. The DB-ALL handles all the functions through the CAN bus system. The T-Harness takes care of all that.
To start the truck with the 10 pin black harness, you simply put the GWR wire (#10 Blue/White) to ground, then 12v to the ignition wire (#9 Pink), and then 12v to the start wire(#8 violet) long enough to start the truck. This will "remotely" start the truck through the DB-ALL.
To get the DB-ALL to lock the doors, you pulse the #1 Green wire to ground. Just touching the wire to ground, will cause the DB-ALL LED to flash and the doors will lock. The same thing can be done with the unlock.
I can get the doors to unlock and truck to start with the black ten pin but still am havin no luck with getting it to start with the fob. When I go in to program the rf out their are four options. Does this sound right?
Old 04-12-2012, 08:34 PM
I got it working on my truck today. I had a local shop reflash it making sure the RFTD was set to out. plugged it in and works like a charm!
Old 04-12-2012, 09:39 PM
Man, that's great news! I will go ahead and purchase me an XK loader 2 and see what I can get accomplished.
Thanks for the update!
Old 04-12-2012, 10:15 PM
kdramman kdramman is offline
Vehicle: 2009 Ram Crew Cab 4x4
Rep:78
kdramman will become famous soon enough
Good to hear you got it working.
