Old 03-13-2012, 07:54 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
dodges resale value is always less than ford, maybe more truck for the money by choosing dodge.
Old 03-13-2012, 07:58 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Originally Posted by bighorn 08 View Post
ive owned both I owned a 05 supercrew and a 08 ram with the hemi. the ram had way more power than the 5.4. but the ford was way roomier. if you want power and probly a little cheaper price look at the dodge. but if you want more room look at the f150 it just all depends on what you want. believe me the backseat was not very comfortable in my 08 dodge quadcab. there just wasnt a whole lot of room not compared to the f150
the ford is pretty roomy but it sounds like you are comparing it to a quadcab when Ram also offers a crewcab.
Old 03-13-2012, 08:00 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^I agree. The front room in the dodge definitely has more room.
Sean
Old 03-13-2012, 11:03 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Nothing has more rear seat room than the Dodge Megacab
Old 03-15-2012, 02:35 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
I agree with the person that said you really can't get a bad truck these days from the big 3. We have had a lot of GMC's, Chevys and Fords over the years at work. Its a little hard for me to compare because my work always buys 2 wheel drives and mine have been 4 wheel drives. Just my personal opinion, but I've always like my Dodges best, the Chevys and GMC's next and the Fords last.
The Fords 5.4. Is that the engine with plug problems? I know Ford had a lot of problems with spark plugs in the 5.4. Did they fix it for the years you are looking at? I'd research that before buying a Ford.
You have to work a Diesel to make it last? I can't agree with that, and I think its a myth. Its easy to say after you have problems that was the cause. Maybe this is true on the newer DPF vehicles.
Old 03-15-2012, 02:41 PM
snrusnak's Avatar
Rep:1385
Yes it is. Huge issues with broken plugs stuck in the heads on the 5.4L's.
If you have this engine in a F150, get the plugs done AT THE DEALER, otherwise you'll be pulling your heads off to tap the plugs out.
Sean
Old 03-15-2012, 03:43 PM
RamManCan RamManCan is offline
Vehicle: 2010 Ram
RamManCan is on a distinguished road
I had a '04 Ford FX4, extended cad with the 5.4. Not a bad truck. As far as the plug issue, I have heard some horror stories. I had mine changed at 110,000km when it was 6 years old with no problems. I have never rode in the '04ish year Dodges but I know my Ford seats were not really comfortable. The driver seat was OK 'cause it was power, but the passenger seat was not, and with the extended cab the back seat wasn't very roomy or comfortable compared to the crew cab Ford.
Currently I drive a 2010 Hemi Ram quad cab, and as far as fuel economy, both trucks average the same, maybe the Ram is slightly better but its also new. The Ford had more consistent fuel milage of about 17-18mpg. I find the Dodge averages the same but the range varies much more(much better on the highway, but much worse in town) Also, my dad has had the 4.6 and we had them at work and they tow just fine, if you are towing frequently, and max. capacity loads then maybe not, but for everyday use it is a fine engine.
Either way you go Ford or Dodge, I don't think you can go wrong as long as the truck is in good shape and it meets your needs!
Old 03-15-2012, 03:49 PM
snrusnak's Avatar
Rep:1385
^I agree with you, but you were lucky getting 17mpg, that's very good for the 5.4L. All the 5.4L F150 owners I know get like 12-14mpg.
Sean
Old 03-15-2012, 10:53 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
I'm following this thread because I'm researching for a future truck purchase. Trying to choose between the Ram 1500 or 2500 or another F-150. As a former F-150 owner (2001 Supercrew 4x4) I can tell you it was a great truck. As for the plug issue in the older 5.4 engine, there were a couple common issues. First, it was not uncommon for a plug to shoot out of an engine. This was caused by there not being enought threaded surface in the head. The second issue was plugs breaking off when being changed. This was caused by galling of a steel spark plug in an aluminum head. It's so common that Ford made a special tool to remove broken plugs from 5.4 engines. It's very common for a couple plugs to break during a spark plug job. I guarntee every Ford dealership has dealt with these two issues.
Old 03-15-2012, 11:35 PM
ramsport62 ramsport62 is offline
Vehicle: 2012 Ram
Rep:55
ramsport62 will become famous soon enough
17 miles per imperial gallon = 14 miles per U.S. gallon!
