tonneaucovered.com
Old 03-12-2012, 04:08 PM
olecuz olecuz is offline
Vehicle: 2012 dodge ram
Trim Level: longhorn
Color: black and gold
olecuz is on a distinguished road
Default bilstein 5100 quesion
I just ordered a set for my 2012, 4 wheel parts had them. Iv been reading the forums and they say they will adjust to almost 3 in. The 4 wheel parts guy says o- 2 inches. I'm tring to get some 35s on the truck. Is 2 inches gonna do it?
Old 03-12-2012, 05:14 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Unless they have changed something with the 2012, the Bilsteins have five settings for the fourth gen Rams....stock, 0.7", 1.4", 2.1", and 2.8". The person you are talking to may be referring to the Bilsteins for the third gen Rams which do not have the 2.8" setting. Regardless, you should be able to fit 35s with just the 2.1" lift. Height isn't the issue...it's the width that will get you. Depending on how wide you want to go you may need spacers as well. I would look at some photos and try to decide if you would like the 2.1" setting or the 2.8" setting better. I personally think the 2.1" setting is high enough but it's all in what you like. Hope this helps!
