12 Ram Express some new mods - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-20-2012, 04:13 PM
pagan pagan is offline
Vehicle: 2012 ram express
Trim Level: EXPRESS reg cab
pagan is on a distinguished road
i been doing some searching and it seems like this mod might require the dealership to have to flash the ecu in order for the system to recognize some of the console functions. i wonder if they void your warranty right after they do it for u
Old 03-20-2012, 04:47 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Originally Posted by snkmug View Post
ez down mod is great, just make sure you add the extra washer to avoid the cable rubbing on the paint...I got it on ebay.
Thanks for the pic and response.....Going to get one....
Ed
Old 03-21-2012, 08:14 PM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2016 Dodge Ram 3500 Laramie
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Nice MODS, very well done. REP POINTS for the overhead Console w/homelink MOD.
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 03-21-2012, 08:23 PM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Nice work man!! Looks really great...!
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 03-27-2012, 12:59 PM
snkmug snkmug is offline
Vehicle: 2012 Ram Express
Rep:13
snkmug is on a distinguished road
Originally Posted by pagan View Post
beautiful truck. i love the overhead console. did you have to replace the headliner or did you cut the original to fit the overhead console? i really want to do that mod. where does it plug into? does it also have that greenish map light? please more info, ive never seen that mod before.
I scored the overhead console on ebay with the bracket for 100 bucks, you have to remove the driver side sunvisor and clip, and the passenger side clip. Take off the drivers side pillar and the headliner will come down far enough to get the console bracket in there. Non-overhead console trucks have plastic spacers under the sunvisor clips, so remove them and toss. I then cut a small hole and ran my wiring thru it where the console is going. The switched dome light wires are in the pillar + -, but you need a positive constant for the homelink and map lights to function with the door closed. I made my own harness for this. There is a white/green striped linbus wire on the homelink, but its for the lighting at night of the homelink. I left that and the green led light disconnected, as I did not want the light shining down anyways. Just make sure you have everything wired correctly and then just button up the healiner with the bracket in there, the spacers are replaced by the bracket mounts. Then you can carefully cut around the bracket and keep test fitting the console until the headliner is cut perfect and the console fits correctly. Headliner is foam and cardboard and cuts easy with a sparp razorknife. Overall an easy job, and wont void any warrantys. You can hook up the homelink linbus and have the dealer install the homelink sales code, so it shows on the evic, but it still works with just a positive and a negative, it just will not display the programming on the evic...There are no lights on the homelink buttons, only the ones the light up at night...good luck
Old 03-27-2012, 01:16 PM
joeAEKDB's Avatar
joeAEKDB joeAEKDB is offline
Trim Level: Demon
Color: Mango Tango Pearlcoat
Rep:520
Nice work! How does the tailgate close now? Not too hard to push up is it?
Old 03-27-2012, 03:04 PM
Rep:13
nah works great
Old 03-27-2012, 03:18 PM
918Dodge's Avatar
918Dodge 918Dodge is offline
Color: Metallic Black
Rep:20
918Dodge is on a distinguished road
Looks good.... does the Express not come with the options that you are installing? i.e. overhead, leather wheel with controls.. evic...?
2010 Ram1500/SLT/RCSB/+Hemi
Old 03-30-2012, 04:13 PM
Ram quad's Avatar
Ram quad Ram quad is offline
Vehicle: 2014 Ram 1500 Crew Cab
Color: Western Brown
Rep:17
Ram quad is on a distinguished road
Thumbs up Nice Looking Truck
Where did you get the overhead console? Did you install it?
Old 03-30-2012, 04:23 PM
Rep:13
it does not come with overhead lighting, or leather wheel with controls. You can get the evic if you order the trailer brake option. The overhead console bothered me the most, I hated not having a maplight to turn on when I needed it. Rolling over the dimmer switch is a thing of the past now aways....
