Old 03-12-2012, 10:41 PM
demco11 demco11 is offline
Vehicle: 2008 dodge ram
demco11 is on a distinguished road
Default BDS lift kit issue
Purchased a lift kit through a supplier online and had a local shop install it for me.
I have a 2008 dodge ram 1500 4x4 quad cab short box
the kit is a BDS 6'' lift with new leafs for the back.
Upon picking my truck up from the shop I noticed the rear is sitting WAY too high.
Does anyone else have this lift kit WITH the leafs? what are your measurments from the centre of the wheel to the top of the wheel well lip?
My front is 26.5'' and rear is 32''.
I checked the part numbers on the leafs and they are correct (both the sticker and the stamped number confirm it) The shop believes they sent me the wrong leaves even though the part number is correct. In talks with BDS about this because my truck looks stupid with how high the rear is sitting when on a flat/level surface.
Should I add a front level kit + bilstein 5100's? is that even possible? I would need to like the front by 4 to 5'' to make it look good but I dont think the rear end is safe having been lifted so high with these leafs.
Old 03-13-2012, 01:26 AM
Jerkbait's Avatar
Jerkbait Jerkbait is offline
Vehicle: 2009 dodge ram 1500
Rep:46
Jerkbait is on a distinguished road
check out this post http://www.ramforumz.com/showthread.php?t=90657 bighorn4life he has a similar set up.. he shud be able to help you. send him a message
-=Ram Or Be Rammed=-
Old 03-13-2012, 05:41 PM
RAM303's Avatar
RAM303 RAM303 is offline
Vehicle: 2009 Dodge Ram
Rep:26
RAM303 is on a distinguished road
Dang, Your better off putting in your stock ones with 3" blocks.
Old 03-13-2012, 11:16 PM
Anyone with the same truck and lift can out there? help is needed urgently to determine if the front kit I got was mislabeled as a 4'' lift instead of 6'' or if the rear is too high.
Old 03-14-2012, 01:28 PM
Schmitz's Avatar
Schmitz Schmitz is offline
Vehicle: 2005 Dodge Ram 2500 4x4 QC LB
Schmitz is on a distinguished road
I'd say both are wrong you have almost 6 inches of difference I'd put the stock leafs in for now, do you know how much higher your front is now than it was stock?
2005 Dodge 2500 4x4 QC LB Hemi, 6 inch lift, 37" Cooper Discoverer STT's, Bully Dog programmer, K&N cold air intake performance throttle body, true duals, debadged.... Soon to come 4.56s and wheels, maybe more lift.
1980 Chevy K20 4x4 9 inches of lift 37" Boggers, 402 BBC, 4 spd, D60, 14ff.
Old 03-14-2012, 04:30 PM
I do not know, measurments were not taken prior to the install.
