Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 03-15-2012, 03:20 PM
Rep:2616
When i built my 1956 Chevy 1/2 pickup
I had to learn about drive shaft angle in relation to to the transmission output shaft & the pinion shaft.
The pinion shaft, for sake of reference, is parallel to the level surface, like your flat driveway, we can use 12" as a measurement from the ground to the pinion shaft
The transmission output shaft is also parallel to the same surface, but is a few inches higher from that surface, we can use 15" as the measurement from the ground to the transmission output shaft
when you install the drive shaft, with a universal at each end, the angle or incline the drive shaft has to make is the difference between 12" to 15", a difference of 3"
If you were to take a PITCH FINDER, that is used on roofs to measure the angle, & hold it on the drive shaft, it will give you the angle of the incline.
This angle of the drive shaft on a regular street vehicle has to be between 1/2 to 5 degrees, depending on the length of the drive shaft.
1/2 to 3 degree angle is preferred
If the angle is more than the preferred angle, you can loosen the rear differential support bolts & use special shims to bring it into tolerance.
WHAT CAUSES U-JOINT OPERATING ANGLES TO CHANGE
Suspension changes caused by: worn bushings in the spring hangers, worn bushings in the torque rods incorrect airbag height
Revisions in components of the driveline
Stretching or shortening the chassis
Adding an auxiliary transmission or transfer case in the main driveline
Worn engine mounts
Raising or lowering of the vehicle
High angles combined with high RPM is the worst combination, resulting in reduced u-joint life. Too large and unequal u-joint angles can cause vibrations and contribute to u-joint, transmission and differential problems. The improper u-joint angles must be corrected.
I hope that i didn't put you to sleep, but this is why the Dealership may deny your warranty claim
Old 03-15-2012, 07:09 PM
Zevox's Avatar
Zevox Zevox is offline
Vehicle: 2014 Ford Mustang
Trim Level: GT
Color: Race Red
Zevox is on a distinguished road
Well Daytona kind of made me think they could fix it, but your gearhead breakdown kind of lowered my spirits!
Regardless, the 60-70's GTX, Challenger R/T convertible, and shiny new red srt8 charger and yellow jacket challenger are distracting me from sadness!
Old 03-15-2012, 07:26 PM
Rep:2616
Hopefully they will go ahead & honor the warranty, it is their option
I was just trying to explain in a rambling way, how it could have happened & why the dealer may decided against fixing it under warranty
Good Luck
Old 03-15-2012, 09:17 PM
Vehicle: 2012 Dodge Ram Sport
Rep:47
I also hate too say it but didn't this cross your mind that they would bring the lowerin up? Its already in my head that I will fix anything wrong with my truck myself as long as its under a few hundred dollars. Anything that's a major problem I will be removing the lowering kit. I also think that I they put it in the computer and already contacted Chrysler then your most likely screwed because it's tagged by your vin #.
Old 03-16-2012, 10:55 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
If you modify your vehicle you run the risk that it might void the warranty but the dealer is required to show the modification caused the problem.
So if you install a CAI it can't affect the warranty on the suspension but if you change something in the suspension they can easily claim it was you fault. Some dealers will work with you more than others but it is a risk.
Old 03-16-2012, 06:21 PM
Zevox's Avatar
Trim Level: GT
Color: Race Red
It'll be fixed Monday, all in which dealership you take it to.
Old 03-16-2012, 06:59 PM
Rep:47
So what did you do?
Old 03-16-2012, 08:22 PM
Zevox's Avatar
Trim Level: GT
Color: Race Red
Just took it to Daytona and it'll be fixed Monday. They don't understand why Beck didn't fix it. Honestly I don't think there ever was a problem with Chrysler because when I called them they hadn't gotten a report from Beck and were shocked they didn't tear my rear end down to diagnose the problem. I know people locally with drop shackles and torsion bar keys I there Chevy and never had a problem with rear ends breaking except for them being dumb rednecks.
