Diesel springs - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-13-2012, 02:56 PM
erion01 erion01 is offline
Vehicle: 1999 ram 1500
erion01 is on a distinguished road
Default Diesel springs
I wa looking at putting diesel springs in the front of my 99 1500 and was wondering how much lift that would give me. I am also wondering if I get the back blocks from the same truck if that woul level it back out or would I need aal also. I also have a leveling kit I haven't put on yet and don't know if I need to do that also or would that be too much lift for stock controll arms. Any help would be appreciated.
Old 03-13-2012, 03:45 PM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:65
gusman will become famous soon enough
2500 springs (if they'll even fit) would make a 1500 ride like a brick. It would be cheaper to get some 2" square stock and weld your axle to the frame...
Old 03-13-2012, 04:02 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
The deiesl springs will fit gives a couple inches lift. The rear block will not as it is 3" wide and 1500 are 2 1/2.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 03-13-2012, 07:39 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
My first thought is that your truck will have HORRIBLE front compliance and will pop a kidney! Those springs are designed to hold up a engine that is about 1000lbs. plus the heavier suspension and such. I would not do that.
Old 03-13-2012, 07:50 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i think the springs you are considering will kill your end components. if you are looking for lift, try some spacers.
Old 03-13-2012, 09:31 PM
I just thought I read on here that's what people were doing and liking te ride. I guess that may not be te case and will look at other ideas.
