welded rear - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-13-2012, 03:16 PM
Reed44 Reed44 is offline
Vehicle: 2000 Dodge Ram ext.cab 4x4 5.9
Color: dark green
Reed44 is on a distinguished road
Default welded rear
I am almost done with my 3/4 ton axle swap and the rear I am using is open. I dont want to spend the money on a posi unit and a friend of mine works at a machine shop and will weld my rearend together so its all time posi. Will I have any issues on the street driving around like this? Anyone here ever done this?
Old 03-13-2012, 03:46 PM
Rep:2954
major wheel hop on paved roads with welded spider gears
major tire wear
a bit of moisture & your vehicle will be walking sideways
Old 03-13-2012, 03:56 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Yeah not a good idea for street driven vehicle. Anytime you turn the inside wheel will skip and be fighting you. Your tires will wear faster and maybe uneven. If you give it gas in a corner the rear will break loose and slide around. Also like GT said in water in a corner good luck keeping it on the road...
Look into a mini spool, they're inexpensive.
Sean
Old 03-13-2012, 04:00 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Color: Green
Rep:31
Big Green V10 is on a distinguished road
I would agree never weld a street truck just a temp fis until somethng comes loose and cost more in long run. Do a spool or just save and do it right the first time.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 03-13-2012, 04:29 PM
Color: dark green
Well I was hoping it was gonna be an ok idea lol. Thanks for letting me know because I almost took it down there tonight and had it done. Im going to look into that minispool and see how much it is.
