Old 03-13-2012, 07:00 PM
draken's Avatar
draken draken is offline
Vehicle: 2010 Dodge Ram 1500 CC Bighorn
Trim Level: Bighorn. SLT
Rep:34
draken is on a distinguished road
Default Bilstein question
Hey, i am looking to get a pair of front bilstein 5100 shocks for my 2007 dodge ram 1500 Quad Cab 4WD. Right now it has a 4inch RC suspension lift on it. I was wondering if someone could help me out on a link that takes me to a vender for these shocks that fits my year and model of truck. My front is lower (probably about 1.5"-2") then my rear, so i am planning on leveling it out with these. Thank you very much.
2010 Ram 3500 Laramie 5" Lift | 35" Nitto Trails 20" Havook Wheels | Sinister EGR Delete | 5" MBRP Turbo Back Exhaust | 6" Black Flo Pro Tip | EFI Live Anarchy Custom Tune | CSP5 Switch | Custom Retrofit Headlights 3k HID Fog Lights
Old 03-13-2012, 07:44 PM
Evil Ram's Avatar
Evil Ram Evil Ram is offline
Vehicle: 2010 DODGE LARAMIE
Trim Level: laramie
Evil Ram is on a distinguished road
Maybe try Summit Racing
Old 03-13-2012, 08:57 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I'm sure they aren't the only ones that carry them but here ya go....
http://www.autoanything.com/suspensi...0A3110750.aspx
You would want the first ones for the front and the third ones down on the page for the rear. If your rear end isn't lifted you will want the 0-1" lift.....$88.95 each.
Old 03-13-2012, 09:01 PM
draken's Avatar
Rep:34
wait so if since my front sits lower then my rear, would i just need the first one for the fronts? and when it says select style, what does "Vehicles with rear 0"-1" lift) mean?
Old 03-13-2012, 11:16 PM
Rep:367
I'm sorry! I'm an idiot. I read your entire post but I wasn't thinking about your 4" lift when I responded. Normally, yes, all you would need to bring the front up level with the rear would be the front two adjustables. Some people buy the 5100s for the rear as well but they aren't adjustable and provide no lift. I don't know too much about suspension lifts so I can't answer your question about the front struts. I do know that plenty of people run the 5100s on the front with suspension lift kits though. Does a lift keep the stock front shock length? That's the only reason there would only be one model available for the front. I'm sure someone that can do more than just speculate will chime in for us, lol.
Old 03-14-2012, 12:52 AM
draken's Avatar
Rep:34
Im guessing it kept the front stock because it only replaced the back shocks from the Rough country suspension lift. Im just confused on what kind of bilsteins i would need for what components i have on my truck right now..Thanks for helping though.. anyone?
Old 03-14-2012, 07:06 AM
Rep:367
That makes sense. I even checked Bilstein's online catalog and they only show one Bilstein 5100 strut for the front. So the same one has to be used on stock or lifted trucks. The rear, however, apparently requires a longer shock after the lift. That's why you can choose your rear lift height when ordering the rears. I feel confident this is the case but if you want a professional opinion and someone doesn't chime in here quick enough I would suggest calling your local 4x4 place (like a 4 Wheel Parts...that's what we have around here) or maybe even calling Bilstein direct. Good luck!
*EDIT* Here's a good thread that you should read. It bounces back and forth between the front and rear but make sure and scan through it all...they even mention your brand of lift. Seems to confirm what you and I are already thinking.
http://www.ram forum.com/f47/bilstei...ed-truck-8442/
Make sure to take out the space between "ram" and "forum" when you copy and paste. Our forum won't let me post a direct link.
