Old 03-13-2012, 09:13 PM
slasher012's Avatar
slasher012 slasher012 is offline
Vehicle: 2005 Dodge Ram 2500
Color: Blue
slasher012 is on a distinguished road
Default Head unit wire connections?
When installing an aftermarket head unit and connecting the adapter harness to the head unit harness what is the best way to do so? I used simple wire crimp connections then wrapped in electrical tape, but a friend said I should've soldered the wires. Are the connections I used alright or should I take the wires out and solder them?
Old 03-13-2012, 09:46 PM
konarider2005's Avatar
konarider2005 konarider2005 is offline
Vehicle: 2009 dodge ram 1500
Color: inferno red
Rep:22
konarider2005 is on a distinguished road
i did the exact same thing you did and i had a professional alpine installer helping me and that was the way he always does it. soldering and shrink wrap is better just because its more permanent and wont have a chance of loosening off or getting pulled out etc. but if you crimped them properly and taped em up tight there wont be a problem at all.
2009 Dodge Ram 1500 sport 5.7L HEMI inferno red
2008 CAN AM outlander 800 xt
Old 03-14-2012, 08:46 AM
slasher012's Avatar
Color: Blue
Alright thanks. I've always used crimp and tape for wiring before and never had any problems but I haven't done something as important as a head unit so I just wanted to make sure.
Old 03-14-2012, 09:58 AM
RamHemi07 RamHemi07 is offline
Vehicle: 2007 Ram 4x4 Hemi
RamHemi07 is on a distinguished road
Just installed my head unit, used the twist and tape method without a hitch.
I've used those pre-wired connectors(had a plug for the factory harness on one end and a plug to match up with the aftermarket head unit on the other) from best buy years ago but couldn't find one.
Try these connector's you can find at Homedepot/Lowe's
http://www.specialized.net/Specializ...00Pk-4053.aspx
2007 QC Hemi Ram 4x4, K&N CAI, Magnaflow, DS Predator
Old 03-14-2012, 05:38 PM
slasher012's Avatar
Color: Blue
I've already installed my head unit a couple days ago. I used normal crimp connectors then taped over them.
Old 03-14-2012, 06:45 PM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
Your method is fine. Don't worry about it. Soldering is overkill. The heat shrink connectors are nice but really not necessary.
Old 03-15-2012, 12:19 AM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
Solder connection are best because it is a tighter, more secure, connection that has lower resistance. Any crimped connection will generally have a higher amount of electrical resistance (This is what I have been told by audio installers and electricians). Having said that, the wiring in question has very low voltage and it isn't usually noticeable if they are not soldered. Installers who insist on soldering do so because they could be concerned with electrical noise being an issue with the source unit connections and it is obviously very durable and has little chance of working its way loose.
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
