Start and Stall problem? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-14-2012, 12:32 PM
jtri5133's Avatar
jtri5133 jtri5133 is offline
Vehicle: 2002 Dodge Ram 2500 SLT 360 V8
Color: WHITE
jtri5133 is on a distinguished road
Default Start and Stall problem?
Ok my wife had my truck for the day and came home told me that the doors kept unlocking themselves everytime she locked them and continued to do it after that too. so i disconnected the power door locks fuse and they stopped working obviously. well now i went out to start it to go to the store and it fired up and not even a second after it died right out. im confused can anyone help me?
Old 03-14-2012, 04:24 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Yes you have probably a short somewhere in the vehicle. I honestly wouldn't know where to start haha... Err, ah, I guess maybe you can try checking all the wires for cuts or anything, rats have a tendency to chew they up! (Guess how I know) Next thing you could try to check is the ECM it might be the reason for the stalling but if their is a short could cause that also. Maybe check the grounds, that might be it. Intermittent ground can cause some freaky problems. Matter fact some dodges and alot of GM vehicles are known for ground issues, fords are known for their exploding gas tank.
Old 03-20-2012, 11:22 AM
ThompsonFarms ThompsonFarms is offline
Vehicle: 1996 Dodge 1500 4wd
Trim Level: SLT Laraime
Color: Hunter Green
ThompsonFarms is on a distinguished road
My 96 did the same thing for some reason it screws up your idler and all you have to do is turn your idle up a little with the screw on the side of the throttlebody and if that doesnt work i replaced the oil pump drive under the distributer also now it works fine
1996 1500 rc/lb 360 cab lights custom camo grill, push bar with 2 kc daylighters 306,250
Old 03-20-2012, 11:43 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Well the other thing is they only mark the most obvius thing controled by that curcuit There are other less curcits on that same fuse. Find a scimatic and look for sub curcits.
