Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 03-14-2012, 06:19 PM
Denix's Avatar
Denix Denix is offline
Vehicle: 2015 Ram 1500 4x4 Crew Cab
Color: Maximum Steel Metallic
Denix is on a distinguished road
Default Tail gate load
What is the maximum load that can be applied to an open tail gate?
Thanks for your help, Denis.
Old 03-14-2012, 06:30 PM
RedRiverRam's Avatar
RedRiverRam RedRiverRam is offline
Vehicle: 2011 Ram
Rep:41
RedRiverRam is on a distinguished road
I'm not sure about Dodge as I've only owned one for about 2 months, but on my previous Fords the general rule if memory serves was 500 pounds.
My OTHER rides are hot air balloons - Coyote Moon and Coyote Rising - aka Dos Coyotes!
Old 03-14-2012, 06:36 PM
Denix's Avatar
Thanks for your answer. But for safety reasons I would like to know it more precisely. May be some body will soon post the answer!
Old 03-14-2012, 09:20 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
i do not know the true answer. but i do know that it depends on the type of load. if you throw a 500 lbs rock on your tailgate it will surely cave in. if you have a 1000lbs palate of bricks on the tail gate and slide it in the bed im sure it will be ok.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 03-14-2012, 09:23 PM
Rep:2804
I think this is what you are looking for
http://www.dgmtailgatesupport.com/
Old 03-14-2012, 09:37 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
The tailgate isn't the weak point, it's the gate straps. It can probably hold at least 1000 lb between the two straps, but 500 lb is a much safer number. Riding my almost 400 lb motorcycle (plus my 220 lb self) up on the gate doesn't ever feel unsafe or shaky, just for reference.
Sean
Old 03-14-2012, 09:55 PM
Vehicle: 2011 Ram
Rep:41
Here's an interesting article on the subject...
http://www.discountramps.com/article...ate-cables.htm
Old 03-15-2012, 02:42 AM
Rep:2804
the DGM tailgate support takes away all your concerns
there is little or no weight on the tailgate cables
click the link that i posted above
check out the supports, try to ignore the woman
Old 03-15-2012, 11:30 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
Higher quality cables or plate hinges like Yankee mentioned would help, but I wonder if there's any issue about the integrity of the tailgate itself? I'm not talking about the cables or hinge plates failing and dropping the load...just curious if the tailgate has some kind of crush or bending potential. Weren't there some pics recently of some Tundra pickups with buckled tailgates that weren't cable or hinge related? I didn't start this post, and I'm not personally all that concerned about failure of either the cables or the tailgate frame itself. I don't think I'll be overloading mine to a failure point. I have belonged to an off road club for over 30 years, and I've seen friends load all manner of vehicles into the backs of their pickups...ATVs, UTVs, big road hog motorcycles, etc. The only damage I've ever seen occur was when someone got a little rambunctios and hit the front end of the pickup bed, denting it or even denting the cab...or breaking the back window...LOL! I once loaded my '83 Honda Goldwing into the back of my '88 Chevy S10 longbed pickup. The tailgate had linkage plates instead of cables, however. As long as the tailgate cables are not damaged, maybe this is an overstated concern?
Old 03-15-2012, 11:41 AM
snrusnak's Avatar
Rep:1388
I would think the tailgate metal would probably take like 4 times the weight as compared to the cables, before becoming compromised.
Sean
