dash question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-23-2012, 11:32 AM
hemi91's Avatar
hemi91 hemi91 is offline
Vehicle: 2007 dodge ram hemi
Color: red
hemi91 is on a distinguished road
Default dash question
Hi my mom has an 01 dodge ram SLT Laramie and her dash is cracking into many pieces. I was wondering if anyone else has had this problem?
07 ram 1500, 5.7 hemi, k&n cai, 14" magnaflow, magnaflow y-pipe, 87 octane tune.
Old 02-23-2012, 01:22 PM
Rep:2929
Almost all those dashes crack & eventually start breaking apart
Several companies make ABS covers that that seem to be pretty good
http://www.google.com/#sclient=psy-a...w=1024&bih=550
Old 02-23-2012, 03:42 PM
Ripley9223's Avatar
Ripley9223 Ripley9223 is offline
Vehicle: 2014 RAM Laramie Longhorn 6.7L
Trim Level: Laramie Longhorn
Ripley9223 is on a distinguished road
It's a very common problem. I had a 99 ram 1500 with the dark interior package and the dash cracked and fell apart as well; to the point were I had large holes where I'd lose things in. Haha my other ram has the lighter interior package and hasn't had the problem as bad as the dark interior package. I read somewhere that it had a lot to do with the amount of carbon used in the manufacturing process.
LMC truck makes a replacement dash (for all interior packages) for a very reasonable price
Cheers, Cody
1999 2500HD Sport (SOLD), 2014 RAM 2500 Laramie Longhorn 6.7L
Old 02-24-2012, 09:52 PM
hemi91's Avatar
Color: red
thanks for the info.
Old 03-02-2012, 05:56 PM
NPoulos NPoulos is offline
Vehicle: 1999 Dodge Ram
Trim Level: SLT Laramie
Color: Emerald Green pearl coat
NPoulos is on a distinguished road
just pull it out and fiberglass it I am doing mine right now
99 1500 4X4 Ext cab 5.2 SLT Laramie http://www.flickr.com/photos/npoulos...7629162633641/
Old 03-07-2012, 07:48 AM
jowwo's Avatar
jowwo jowwo is offline
Vehicle: 2001 ram 1500
Trim Level: base
Rep:35
jowwo is on a distinguished road
It sounds like the '97 and older, you have to pull the whole dash to get the top off, but the '98 and newer the dash pad can just be unscrewed and replaced. Anyone know if this is true? I'd like to put in the replacement dash from LMC.
HIS: 2001 quad 1500 318 5spd. 1998 Wrangler 33s
HERS: 2014 Express crew 1500 Hemi. 1973 CJ5 33s
Old 03-07-2012, 12:30 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
There's more to it then that there are bolts in fire wall and knee bulsters steering collom,air bag on pass side must come out. I've been looking into it for my 01. 98 to 01 are same dash set ups.
Old 03-07-2012, 12:40 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Now if dash is just cracked andnot missing pices like mine id go with dash cap idea there would be no need to pull air bag or any of the other isht. Mine is missing a big pice in middle though they say you can still use a cap on them holes and all.
Old 03-11-2012, 03:07 AM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
If you go with a cap, make sure the installer really cleans the dash first, and uses plenty of silicon over the contact areas. Also, once you set the cap, and are waiting for the silicone to dry, you will want to have some pressure on the cap, holding it against the dash. You can use some small towels or dish rags to wedge in between the windshield and the cap.
If you don't do this, you will most likely have a lot of rattles.
Someone installed a cap on mine before I bought it. I'm very surprised at how good it looks. It looks like a normal dash. Unfortunately the installer did not do a very good job with the silicone, but I've been able to squeeze some silicone in the problem areas, and it rattles only a bit now.
Old 03-11-2012, 10:27 AM
ramfam's Avatar
Trim Level: Base
Rep:21
There are truble spots with caps the edge is one of them
cracking, dash
