Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8
Old 04-13-2012, 07:03 AM
MERF-09's Avatar
MERF-09 MERF-09 is offline
Vehicle: 2001 Dodge Ram
Rep:19
MERF-09 is on a distinguished road
Originally Posted by ChillyPhil View Post
Can you do these throttle body mods when you have a cai installed?
Yes I have a homemade CIA I made from a Dakota intake.
One Owner 2001 3500 Cummins 320,000 miles & still growing & 2001 1500 5.2 92,000 & still growing
Old 04-19-2012, 07:37 AM
MERF-09's Avatar
Rep:19
Alright I have the mileage for the first tank after throttle body work previous is 15.17 mpg on this tank 15.86.
I also revamped my homemade CIA.
Old 05-10-2012, 07:58 AM
MERF-09's Avatar
Rep:19
Second tank results are 16.89mpg I would say the throttle body mod is well worth it.
Old 05-19-2012, 02:56 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
Been wanting to figure out how to install my electric fan I got off a Mark IV. Like what you did MERF-09 with the overflow and washer fluid tanks!
Old 05-24-2012, 08:08 AM
MERF-09's Avatar
Rep:19
Thanks
I ran a Lincoln fan till the low speed went out I will take some pics of my current setup it is the same as the setup I used on the Lincoln fan I ran the low speed off the adjustable temp sensor & the high speed off of a Cole Hersee 85 amp continuous duty solenoid. Cole Hersee solenoids are rated for 5 times what the amps say. The Lincoln fan pulled about 100 amps at start up & ran 40 amps at regular speed on high speed.
Old 05-24-2012, 01:32 PM
MERF-09's Avatar
Rep:19
The first pic is the adjustable Hayden fan relay that triggers the Cole Hersee solenoid second pic is the Cole Hersee solenoid its hooked to the battery positive & negative & then back to the electric fans. I'll see if I can get some more detailed pics.
Old 05-24-2012, 10:01 PM
Paul89's Avatar
Rep:20
I know we're off the subject here but did you have to change the alternator to a higher amperage?
Old 05-25-2012, 07:27 AM
MERF-09's Avatar
Rep:19
No I'm still running the OEM the battery voltage does dip when idling with the air conditioning & the lights & the radio going with the head lights off it does just fine. I have researched a bigger alternator I can run a 160 amp off of a 2001 Durango or the other choice is a Diesel 136 amp the diesel alternator pulls 90 amps at idle were the standard 136 pulls 60 amps at idle. I haven't upgraded yet I'm leaning towards the diesel alternator though that way I don't have to mess with the fuse in the fuse panel under the hood.
Old 08-05-2012, 05:45 AM
MY1stRAM MY1stRAM is offline
Vehicle: 2001 ram 1500 4x4
Color: blue
MY1stRAM is on a distinguished road
I just got my ram, (always had ford rangers) and what is it exactly that cutting down the raised edges does? If it's worth it I i might go for it myself, I'm just not sure of the purpose behind it
Old 08-06-2012, 01:03 PM
MERF-09's Avatar
Rep:19
Cutting the edges off lets the engine get more air & less restriction of the incoming air.
